Posted (edited)
I was wondering if I should upgrade to the big 3 even though I have a stock alternator and stock battery. I'm not pushing anything big in my car either. How much more improvement will the big 3 do for me? Also, should I upgrade from my old ass reused 8gauge with some KnuKoncepts 4gauge?
In all, will doing the big 3 and adding 4gauge make a helluva difference in to my system? Oh, one more thing, what's the difference between this 4 gauge KnuKonceptz kit
KnuKonceptz Complete 4 Gauge Amp Kit w/ 120A MIDI FUSE
and this 4 gauge KnuKonceptz kit
KnuKonceptz Blue/Silver KLM 4 Gauge Amp Install Kit
Edited by k3n12ock
different fuses
Well yeah. I should have been more specific. What I meant to say was, is there really any difference from the 4 gauge provided compared to the other? Just wondering because you know, one is like $13 cheaper.
cheaper is copper clad aluminum and the more expensive is pure copper.
the more expensive is also way more flexible.
you won't tell a difference unless you're putting alot of power through it.
what kind of power, setup do you have?
Alpine CDA 9830, Soundstream Picasso PCX1000D @ 2ohms running 2 PBX 12's DVC 2ohms in custom box tuned to 32hz
you'll be fine with the cheaper.
i think the flex (more expensive) looks alot better and it is alot easier to run through your car IMO though.
Cool. I think I'm going to get that $39.99 kit. Next I need some 0/1 for THE BIG 3.
Just ordered the 4 Gauge FLEKS and and extra 5' of the blue and 5' of the black power fleks wire. Will be here in a few days. Do you think it'll be alright to upgrade the big 3 with just 4 gauge or should I just do it right and do it with 0/1 gauge? How much, in feet, do you think i need? I have an 01 Impala.
Posted (edited)
any wire upgrade you can possible do will help thing out. :)
I would agree any upgrade in wiring to get power from source to amp will make a difference
as far as that you may want to do 0/1 just incase you upgrade your setup later plan ahead ya know
Edited by Jville140db
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
