Bumpindemlowzz Posted June 17, 2009 Report Posted June 17, 2009 Ok im starting my enclosure build for my dc level 4 15". These are the measurements i have so far... 15.750 for depth 20" height 34" Width 3" Port Width 12" Port Length 55.5- Port Area Comes out to 4.009 cuft at 32.45 hz. My question is should the Port Width be fine to avoid port noise or turbulance? Also i was thinking of doin a double baffle on the outside of the enclosure for a flush out but should i do a inner baffle? These measurements are without displacements aka woofer or baffle. Just wanted to double check should be good to go. I already started with the other peices of mdf and even with predrilling and countersinking the mdf seems to split any tips? 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
Guest Posted June 17, 2009 Report Posted June 17, 2009 as i just said in your other topic, you will be fine with 13.87sqin of port area per cubic foot of box. i definitely think you should do a 2nd baffle, above the box. that way you dont lose any displacement and you strengthen the box. btw, to find out how much port area you have per cubic foot, you do the total amount of port area. in your case you had 55.5sqin worth. then you divide that by the cubic footage of your box, 4cuft. 55.5/4 = 13.87sqin per cuft. the ideal number is between 12-16.
Decaf Posted June 17, 2009 Report Posted June 17, 2009 12" is not 32.45hz give me sec ill edit this with ur box: same dimensions 3.514cuft 32.45hz 55.5sqin/3" wide port 33.5" total length of port down center of port 11.25 and 17" port walls do an outside baffle... it will drop ur tuning a tiny bit, but round over both the entrance and exit of the port and you equal back out
Bumpindemlowzz Posted June 17, 2009 Author Report Posted June 17, 2009 cool thank you. Thats a cool program btw decaf. ohh yeah how to you guys stop the mdf from splitting? I predrilled and countersunk but still happening. 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts
Guest Posted June 17, 2009 Report Posted June 17, 2009 cool thank you. Thats a cool program btw decaf. ohh yeah how to you guys stop the mdf from splitting? I predrilled and countersunk but still happening. alls i do is predrill and it works fine for me.
Decaf Posted June 17, 2009 Report Posted June 17, 2009 say you are using 2" drywall screws.... go 2.5" down with ur predrill and make sure you are using a 1/8 bit (iirc) that usually helps me... and use more torque than speed so you dont mash the screw in.. remember its to hold the glue in place... the glue is stronger than the screws you put in.... do them every 3-4" usually
Jville140db Posted June 17, 2009 Report Posted June 17, 2009 hmmm never did screws always did brads, tightbond 3, bracing with screw don't know if that counts and liquid nail instead of caulk on all inside seams never had a problem just was wondering why everyone seems to use screws never got it seems it would lessens the wood structure in the long run by having such a big hole in the edge oh each piece. Car is 2010 Scion Tc Currently in car Deck- Sony XAV-60 in-dash mobile video system Speakers- Rockford Punch 6.5in comps in the front and coax in the rear Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service Wiring- all rockford nuff said Enclosure- Dual 12in custom box by SRQ Battery- Optima Yellow top with big 3 done Sound Damping- All Dynamat products 1-2 layers throughout with liner on top Link to my build log- http://down4sound.co...=newpost&t=5275 Link to my youtube- http://www.youtube.c...ser/Jville140db MECP Advanced CEA # 110531 BassBox 6 Pro for Box Building/Re audio box calculator If you can hear the passenger it aint loud enough!!!!!!! QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
