I really hate cars especially small ass ones for bass, but it's what i have to work with for now, so i put in 2 l brackets with screws cuz they came with them, and i could barely get 2 in anyway and one of them moves :(
Anyway this is about as good as it's going to get for this car (i've had this done for a while btw):
The bracket that doesn't quite hold because there is metal under it so it's just screwed into the carpet lol
The bracket that does hold
Any suggestions to make the box hold better and not slide?
When does it slide, when your driving or when you bump?
Cuz when I had my system going (Two 12") my box didn't slide around when I drove and I'm pretty sure your box and sub weighs about twice what mine did.
But if you still need to brace it try bigger l brackets.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
i guess it could be both, before i had anything to hold it though, it was when i turn a corner usually it would slide. I think the shti blows those brackets off though lol
Well the brackets you have on it look tiny on that box, do you have a pic that shows your whole trunk?
Well even if you don't, what I was thinking is that you could push your box until it's leaning on one of your trunk walls and then practically fill the opposite side with brackets, or you could put a few bigger one.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
get some 1 1/2" or 2" angle aluminum and use some long screws to go through the car's metal
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
band iron zipscrewed to the rear deck, then screwed into the box
ghetto but it works...i wouldnt suggest screwing into the metal, most cars have a gastank thereabouts
or if you wanna go all out, take the carpet out, lay it on 1/2 inch plywood, trace it, cut it out, staple/glue the carpet on, and then screw the box to that (which is what i did, and never had an issue again)
Team DC
Kitchen mat under the box and you can take turns as fast as you want without worry, but are you going to trim down those 1/0 wires going into the amp, because one bump or whatever and those wires touch. By By amplifier. My .02
I would definitely get some electrical tape around the ends of your wire or buy some distribution blocks for the 1 gauge to 4 gauge conversion.
