^ What Bullet said- lol
1) reinforce shed, 2x4s maybe?
2) Dynomat, lots of it
3) Blow thru FTMFW
if doing blow thru, resin the box, then paint with bedliner ;-)
rain hates MDF
add some tweets to youre sub boxes or build some by9 boxes and add some to youre system
but deffinately put youre by9s in the ceiling for the surround effect
2 12's i would happily help you design them send parameters!
these are for the dual 4 Ohm. and his is single but i think theyre almost the same.
Fs: 29.19 Hz
Qms: 6.67
Cms: 0.265 mm/N
Mms: 112.18 g
Rms: 3.08 kg/s
Vas: 3.871 ft³ (109.60 liters)
Xmax: 0.370 in (9.40 mm)
D: 10.350 in (262.90 mm)
Sd: 84.14 in² (542.84 cm²)
Vd: 31.14 in³ (0.51 liters)
Qes: 0.63
Re: 1.62 Ω
Bl: 7.27 Tm
Prms: 225 Watts
Qts: 0.576
ηο: 0.417 %
SPLo: 89.10 dB
SPL 2.83V/1m: 95.25 dB
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
