OK so when i built my box it was tunned to 33Hz so i added,not thinking it would hurt the tunning, i put 2 2x4s going up and down and 1 2x4 going from front to back. i later found out it changed it to 40Hz i was mad.So SPLGEO told me i could shorten the length of the port by adding a piece of mdf wood to the sides of the ports to the back until the bass was low enough.I cant tell whats good so can somebody please tell me how much shorter i will need to shorten the ports by adding 3/4 mdf pieces. here is what i built. i am going to put the origanal box design up. this is double baffled also.Please help! THANKS.
Edited by alpine
BANNED LIKE A MOTHAFUCKA
IM BANNED BECAUSE IM A FUCKIN FUCKTARD
this is for 4 alpines?
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
well thats the problem the guy who designed the box said to add 2" to each end of the port but if i do that my subs wont fit, her is a pic, where the port turns if i add 2 " the sub wont fit
have you heard it play yet? you may like 40hz, i wouldnt, but some do. but it kinda sounds like your screwed. you could take the 2x4s out and brace from the outside....by kinda wrapping the box in 2x4's...but then your box might not fit in your car...sounds like you are either gonna have to live with it or rebuild it...
i likes me some audio stuff...
Just invert the back two subs after you lengthen the port
i will never invert my subs no point
... it would make up for the added 2x4 room :rolleyes:
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
  • Who's Online   0 Members, 0 Anonymous, 1096 Guests (See full list)
