Subwoofer Flexing Too Much?
ps6435
yes...if you play under the tuning freq which ive said like 4 times.
510w? the amp can only do 400rms at 4 ohms bridged.
its wired up at 2 ohm...
it just sounds to me like your box is tuned way too hight.... get one built with a tuning frequency in the low to mid 30hz range... and you will be slammin on the lows.... imo you shouldnt have a box that is tuned 40hz and up unless you are burping...
This is what is going on, Your box is tuned to high. Unless you are going to be competing and burping tones mostly you need a new box or retune the one you have.
My box is tuned to 60 so I know exactly what you are talking about. If I drop my subsonic filter down low and turn it up I get the same problem as you are having.
bridged? or using both channels. because i dont think that amp is stable at 2 ohms bridged.
the website says this amp is stable at 2 ohm i only have one subwoofer and its wired up at 2 ohm and its hooked up to left channel positive and right channel negative which is how you do mono... because on amp it has chart for mono and points to those two...
the only way you can check if the amp is pushing the sub too hard is with a dmm. or an oscilloscope. those are pretty much the only 2 options.
the sub can sound like crap when your playing too low of a note and the sub is over-excursion'ing (word?) itself. set the subsonic filter to about 40hz (if the box really is tuned to 45hz). or if your clipping the absolute hell out of the amp.
So now Oscilloscopes can tell you if your pushing the sub to hard or not? Awosme. Which scope do you have? Never heard of them doing that. What does it say on the screen. "Warning, warning, warning...Pushing sub to hard"?
Car Audio + Bodyboarding/Longboarding = LIFE!!!
i meant if the amp is clipping, thanks for the sarcasm ass
how can i know how to tune a port? and also my port is like 3.5 at opening from front of box and when it goes left the port is 4.5 inches wide... port is uneven... it was my first box so i thought it wouldnt be perfect but does anyone have a recommendation on building a good box for my sub?
http://www.ddaudio.com/dd/caraudio/09/woofer09_1500.asp
im using the 12" of this series...
Over-excursion'ing? You mean overexerting? Man this thread is full of fun.
help the guy or gtfo
if i were to get a bigger amp that pushes around say 1000 rms and had gain turned down less would i have less chance of clipping?
  • Who's Online   0 Members, 0 Anonymous, 512 Guests (See full list)
