Quick question. I never installed an amp wire kit that didnt already have the fuse in place. I heard that it's a good idea to have the fuse as close as possible to the positive battery terminal but I was wondering just how close does it need to be? I was thinking about installing it about after a foot and a half on the wire is that ok?
I think within 18 inches is the suggested range, mines probably about a foot or so away. I'd say yours will be fine.
Old Setup
03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2
Highest Score to date: 151.2 db @ Headrest
Yeah if it is 18 I'm fine the way I want to install it. Whats the proper place to ground in a trunk??? I used one of the bolts that was holding in the rear stock speaker on the top inside of the trunk when I installed my 8".... Well I finally get to hook it all up tomorrow :D :D
You can ground the amp pretty much anywhere. you just have to make sure that you mount it to bare metal. the ground wont be sufficient if its not.
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
