SPL Amp
Thinkin about getting this amp for my 2 15's cvx. Or should I get the Us amps merlin 3d.
http://www.sonicelectronix.com/item_17908_...LA5500-1D-.html
# Gorilla Series Class D Digital Monoblock Car Amplifier
# RMS Power Rating:
* 4 ohms: 1700 watts x 1 chan.
* 2 ohms: 2500 watts x 1 chan.
* 1 ohm: 3200 watts x 1 chan.
# Max power output: 5500 Watts
# Regulated MOSFET PMW power supply
# Bass Remote Details (Wired remote bass level control included)
# All connections on the front side for easy installation
# LED power indicators
# Bass Boost (0-18 dB bass boost at 45 Hz)
# Phase Shift (180 Degrees)
# Mono channel operation
# Bridged Synchronization (Strap amps together to double your power!)
# Preamp RCA outputs
# 3-Way system protection circuitry (thermal, overload, and short protection)
# Brilliant silver texture coat finish
# Heavy duty die cast aluminum alloy heatsink for extreme heat dissipation
# Silver-plated RCA level inputs
# Silver-plated screw terminals
# Variable low-pass filter (40-200 Hz, 12 dB/octave)
# Subsonic Filter (12 dB at 20-50 Hz)
# Frequency response: 15-150 Hz
# Dimensions: 17"L x 8-1/4"W x 2-1/8"H
Are the subs 2 or 4 ohm?
whats your budget?
Edited by St.Ides
TNCB
....my damn room was shaking, im like wtf is this how am i gonna die jakin off to vida guerra?
a little math and you will find that amp is overrated by 400 watts. 40a fuses x 5 = 200 x 14.4 = 2880
And what 3200 rms do you know that wants dual 4 gauge inputs
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
Words to live by.
hifonics is a peice yeah i know i have them and it pushes my subs just fine but if i could do it again i would soo go with sundown, rf, dat, us amps
and you forgot effiency and pry gunna have voltage drop... thats all ill say :D
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
this is a very basic way to get really approximate numbers, but you also have to factor in efficiency. no amp will be close to 100% efficient. so to take a guess with the amp being 70% efficient, it will only be putting out round 2000 watts rms
x2 on the md3
head unit - Panasonic MXE CQ-C7403U
amp - Cerwin-Vega EXL 1200D
subs - (x2) Cerwin Vega V-MAX 15.4
box - 5.8 ^3 at 32hz
spkrs- Phoenix Gold Rsd Comps
  • Who's Online   1 Member, 0 Anonymous, 459 Guests (See full list)
