I got my new DC3k the other day and I'm goin to set the gain with DMM. My question is when i set it I want 1500 to go to each lvl 4 xl.. SO... so i set it two 1500 or 3000 with the DMM?
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
depens what ohm you running on the amp
Edit: what ohm coils and how you going to wire them to the amp?
Two 12" lvl 4 xl D2 to a 1ohm final load. Wired separately with 2 positive and 2 negative going to the amp
You dont use a DMM to set a certain wattage you set the voltage.
Exactly but in order to do so I was wondering if I need to set it to 38.73 (1500RMS) or 54.77 (3000RMS) on a 1ohm final load. 3/4 Volume with 50hz tone etc..
Edited by SojiaRaggs9000
sorry to tell you this but you not going to get those subs to 1ohm on one amp with 2 d2 on one amp you got .5 ohm or 2ohm
so your best bet would be to use the 2ohm one unless your sure your amp can handle .5 stable
each sub is wired separately like above. 4 leads to the amp. Set it with the dmm to 54.77 then??
Is this a 2ch. amp? cuzz if its mono then your gonna get .5ohm or 2ohm like arcane said
93 Chevy Silverado
Crossfire,Dayton
Soon to have 6 Lvl4 15s
DC Audio Dealer and Team Member
Not sure if the PAI 3000.1 are 2/1 like the RF T3ks specs on of the amp are:
RMS power - 2 ohm linkable/dual mono 5400W x 1
RMS power - 1 ohm mono 3000W x 1
RMS power - 2 ohm mono 1500W x 1
RMS power - 4 ohm mono 750W x 1
  • Who's Online   0 Members, 0 Anonymous, 1260 Guests (See full list)
