I've got the 8000k headlights coming. So, I'm thinking about getting some for the foglights. And then my next question is, how do I wire up the foglights to stay on with the headlights??
jason
p.s. I've been doing some changes to the Tahoe. As soon as the exterior is done, I'll reveal it. :yahoo:
Float mounted IPad Mini playing through Bluetooth
IStreamer for Iphone or Ipad
Rockford Fosgate 3Sixty.3
RE Audio XXX 6.5's in each door with a second set soon to be added to the front doors
Two Rockford T600-4's for the components
Blowthrough with two Sundown SA-8's
RF T1500-bd's for the subs
8000k H.I.D.'s in headlights and fogs
Lifted 2" in front and 2" in back (soon to be installed a Suspension Maxx 1.5" body lift)
17" Ultra Rogue 175's on Nitto Trail Grappler 285/17 70's
Undercover Bedcover
Surco Roof Rack
Five Hella Lights on front bumper
270A Mechman Alternator
Two Optima Yellow Top batteries
Dynamat double layered each door and roof, quadruple layered on back wall, single layered on floor with Second Skin Luxury Liner Pro on top.
ied wire my foglights in with the parking lights, thats how i do it sometimes, so when the parking lights are on there on, so there kinda like driveing lights, n then turn on headlights?
but u can wire off the pos low beam wire n they will stay on all the time, are u gettin 8000k h/l or just low beams? i can make it work but i dont kno exactly how to type it out on how to do so, but its acually easy to do, my regular headlight wires had enulf currnet flowing so i didn't need the whole ballast treatment for my hids, and
www.futurevisionhid.com is a good place, and alot cheaper than what i payed for mine, n there part of smd so that makes it all the better
hope this helps
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
use a relay bro from the headlight wire......its easy.
oh no, any minute the fuc#king HID police, aka Stephen is gonna give you his 2 cents - i can feel it coming. :diablo:
Follow my Tweet (Twitter)
hope this helps
ummm if you dont have a ballast then you dont have HID's. You cant just hook up an HID bulb to 12vDC like a halogen and have it work. They dont work that way.....maybe i am misreading what you are trying to say.
i just looked at some of your pics, i see a ballast......so im sure i misread what you were sayin' or you didnt express what you were tryin to say very good.
http://www.futurevisionhid.com/fog-light-k...c-35_48_43.html
and i didn't mean balast, i ment the relay deal, from headlight harnes to relay switch to battery 12v n what knot, mine just has prongs thats wired to a plug that goes into ballast, guy said mine were good enulf to power the ballasts without the relay harness, so it worked out for the better, but still yet i gave $200 for my hids n fvh are alot cheaper n better quality seems like products
thats what i figured....
anyway for wiring in fogs to turn on when the headlights turn on, definitly use a relay.
but ya u can wire it threw a relay setup, its pritty simple, why steve said a relay cause its a lil more leanient on the power u get than just tapping str8 into the headlight wireing, just run a pos wire from battery to relay, either a highbeam, or low beam pos wire from headlight wireing, or just tap into the relay harness that comes with ur hids to turn on the ballasts, n then just wire that into other relay n ur set
i wished i knew how to type it out as to show it in person, but its almost as simple as installing regular hids, just a little rewireing diff stuff but still works, and make sure u heatshrink the wire cause electrical tape comes off with road grime n what knot, but other than that good luck with ur truck man
this should be sufficient for wireing this
http://www.parts-express.com/pe/showdetl.c...tnumber=330-073
http://www.parts-express.com/pe/showdetl.c...tnumber=330-074
and if u need it
http://www.parts-express.com/pe/showdetl.c...tnumber=500-001
if u dont want to tap into the hids relays wireing u can go this route, n get all u need for around $5
Thanks guys. Always appreciated. I'm gonna order the H.I.D.s for the foglights probably early next week. Will they work with the factory foglights I have on my LS or do I need to upgrade? What kind of bulb should I be getting??
And Steve, when am I coming out to do some tattoo work and get those 24's from ya??? :spiteful:
Undercover Bedcover
Surco Roof Rack
  • Who's Online   0 Members, 0 Anonymous, 643 Guests (See full list)
