Airborne Posted July 2, 2009 Report Posted July 2, 2009 I'll gladly design you a box for those L7's if you want. Just let me know how much room you have and what frequency you want it tuned to. Oh yeah, I highly reccomend doing precision ports in the box too. They are the round ports with flares that can be had on partsexpress for like $14 each for 4" ones. For your setup I'd reccomend at least 4 of the 4" ones or maybe even 2 of the 6" ones. The only problem with the 6's are that they cost like $37 each. If you want some help with a new box pm me and I'll help you for free. I've designed many boxes for members here on the forum and have never had a complaint, not to mention that my car is one of the loudest 2 15 in a no wall setup here on the forum off of a measly 3500 watts. I've got the deebeez for you http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gifI will never build a box with anything else. Now before anyone trips out, I mean walls too! I just need permission from momma and a mini van.
CHINO11550 Posted July 2, 2009 Report Posted July 2, 2009 the w7 is a fuckin monsterI strongly disagree H/U Pioneer deh80prs w/ HRT iStreamer Ipod DACFront stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweetsamp running 4mids, Mosconi Audio 300.2amp running 8tit & alum tweets, Mosconi Audio 200.28 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'zbox is a 4th order band passbatts. 1 XS Power D3400 under hood,6 D3100 in back2 XP 370 amp DC Power alts.MLA module 15+voltsAll in a 97 2door Tahoe LT2010 West Coast Reg. 140-149.9 Bass Race Champ Team Bass Hz
TyC2010 Posted July 9, 2009 Author Report Posted July 9, 2009 http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=3 I would wire them to 1.34ohm, alot more power outta the amp that way I wired them to this and when i turn them up. they cutt out when it gets about 1/4 the way up. I dno what it is. i double checked the wiring and everything. any thoughts.
littleitaly1990 Posted July 9, 2009 Report Posted July 9, 2009 Damn man when you build a box with the specs the guys on here give you, you will DESTROY that W7, hands down. also, when you wired it down to the 1.34, did you have your gains set properly, because if you were clipping, that would be a problem, but if not, I doubt it would be. A vitrolic, megalomaniacal sadistic psychopath.
TyC2010 Posted July 9, 2009 Author Report Posted July 9, 2009 Damn man when you build a box with the specs the guys on here give you, you will DESTROY that W7, hands down. also, when you wired it down to the 1.34, did you have your gains set properly, because if you were clipping, that would be a problem, but if not, I doubt it would be. i adjusted the gain to where it doesnt cutt out but it was so much louder when it was wired to 3 ohms. i dnt get it
