Posted (edited)
Sorry if these are actually pretty stupid questions, I just love fooling around with my system and want to get a few things straight...
1. What does RCA stand for? (cables)
2. When connecting the RCA cables from an amp to a head unit, does it matter whether if they match up with positive/negatives on each unit? (they come in strands of two, does one have to connect to both positives and other both negatives?)
3. The wire that goes from your amp to your sub(s), what is it usually called?
4. Does this wire ^ have to match up with positive/negative too?
5. Why is the wire usually so thin if the wire powering the amp is so much larger like 0gauge or 4gauge?
Hmmmmmm that's all I think of for now, thanks a lot! :rolleyes:
Edited by CPM6372
2. yes
3. speaker wire
4.yes
5. i geuss your talking about the speaker wire and its because it doesnt have to carry a huge charge threw it continuously so thats why they are smaller
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
1. RCA is the company who made it
2. You have to worry about left/right speakers. The tip is positive, outside ring is negative.
3. Speaker wire
4. Absolutely, so you're not out of phase.
5. The power to the speakers doesn't have nearly as much amperage going through it as an amp would.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
1. Really Cool Audio cables :)
2. You can also connect the yellow to the tv, while the red and the white can go to the xbox
3. Easy one, its called wire.
4. No, but then they would be out of phase, usually seen with inverted subs...
5. Thats because there are two wires instead of 1, ie 1+1 = 2 which would be the size of the big wire....:)
Seriously?....
http://www.bcae1.com/ ------->GO HERE
2x 10' Polk Momo MM2104
Alpine MRP-M500
Custom Fiberglass Enclosure
4x Polk db 6.5's
RF 450.4
Pioneer DEH-4000UB
I can't believe how many wrong answers have been given so far...
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
what was wrong with my answers...the cables are really cool :)
Alpine MRP-M500
4x Polk db 6.5's
RF 450.4
Pioneer DEH-4000UB
Just having a little fun, I figured someone would post legit answers. The main point of it was to read bcae1.com. So in the end I did give OP some good advice.
Alpine MRP-M500
4x Polk db 6.5's
RF 450.4
Pioneer DEH-4000UB
