This might sound really dumb, but i'm tryin to learn a little ..... for example if you have a 4 ohm sub with 600 rms .. and your trying to match up an amp to it ... do you look at the amps 4ohm rms or 2ohm rms????
Is it a single 4 ohm sub or a dual 4 ohm sub?
EDIT: I just got Ninja'd
Edited by CaptainzPlanetz
¿ǝɯɐƃ ǝɥʇ
So is it better to get a dual 4ohm or a dual 2ohm sub
Depences on the amp you choose, if you get a dvc you will need an amp that will give you the correct rms at your ohm load. I have a dvc 2ohm and it is wired parallel to give me 1ohm load but if wired in series will give you a 4ohm load. Since at 1ohm I find an appropriate amp that is 1ohm stable that will give me the correct rms for my application
ok so if I would get two 12 inch subs that are dual 4ohm at 900rms each .... can i get a mono amp that says 1*1700 w @ 2ohm ... would that be ok
This website will teach you a lot, you can enter in all your information and it will make the calculations for you basically.
http://www.the12volt.com/caraudio/boxcalcs.asp
I wish i knew these forums existed when i first got my stereo a year and some months ago now. I wouldda know that for the 2 dual 2 ohm subs i had i needed either 2 amps that were one ohm stable that put out 500w RMS at 1 ohm or 1 2 ohm stable amp that put out 1000w RMS at 2 ohms, lol. (or just buy the D4 subs, lol)
ANYWAY
Use the calc on the12volt.com It will help you alot. If you get 2 D2 subs you will end up with a .5 ohm or 2 ohm load if wired to one amp. D4 subs will give you a 1 ohm or 4 ohm load if you wire 2 subs to the same amp. D2s can be wired to 1 or 4 ohms individually while D4s can be wired to 2 or 8 ohms individually.
  • Who's Online   0 Members, 0 Anonymous, 858 Guests (See full list)
