well if u take out the rca's it shuts off. so its grounding through the rca some how. no ground to your deck at all? does it mount to metal in the dash?
Most definitely grounding through the RCAs. The chassis itself is not grounded in the dash. I have a separate wire run from the battery to the radio for a ground.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
It happened to me when i was doing one of my first installs.......had the pos hooked up to the amp as well as the rca's and wanted to check if i had power (using a dmm) so i grounded the dmm and touched the pos terminal.........anyway the amp light came on and i was wonderin what the hell was going on......so rcas do provide a small amount of ground i guess
How is it saving me hours of trouble? I tested the amp with muting plugs, so amp checks out fine. For some reason, it doesn't matter what head unit I use, or which RCAs, it uses the outer of the RCAs as a ground and introduces alternator whine/ignition noise with the key at ignition.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
  • Who's Online   0 Members, 0 Anonymous, 3517 Guests (See full list)
