fox_racin4 Posted July 4, 2009 Report Posted July 4, 2009 well... i have 2 10 type rs in a 2.8 cube box at 31 hz on about 2000rms the sub closer to the port ( slot port) seems to move alot more then the sub further away from the port the port goes into the box 20 inchs to the side what would cause this? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
t-money Posted July 4, 2009 Report Posted July 4, 2009 kinda sounds like a wire came loose from one of them 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
spl4life Posted July 5, 2009 Report Posted July 5, 2009 i agree... speaker wire may have come loose.. or maybe one of ur subs is burnt... are they both powerd my one amp? My first truck... My first Real build... *Update 8/9/10 DC Power 270xp Alt is In!!!* 1997 Toyota T-100 DC Level 5 18" in a T-line Everybody wants their system to be.... 1. Cheap 2. Reliable 3. Loud ...you can only pick two. micahmye hertz pack
Mostar Posted July 5, 2009 Report Posted July 5, 2009 I have a similar problem and i have checked all those things too and it still does it... Also the sub closest to the port get warmer than the other...shit is weird. It could be your enclosure maybe. Just my.02. '05 GMC Envoy H/U: PIONEER AVH P4300DVD Subs: ( SA-12's Amps: (2) SAZ3500d's MECHMAN 270A Alt and 5 Batteries with lots of 1/0
bkolfo4 Posted July 5, 2009 Report Posted July 5, 2009 If the box and sub placement is not symetric, the subs will more than likely not react the same it the box. That is just how it is. . . You cab try adding pieces in the box behind the subs to change tha airflow. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
BassAddict32 Posted July 5, 2009 Report Posted July 5, 2009 yea, to me it sounds like your enclosure. i've noticed with some setups that if one gets more air through the port, it moves more then the one that doesn't get more air out. 1994 Ford F150 reg cab 2 HFX 12's Audiopipe APSM-1300
fox_racin4 Posted July 5, 2009 Author Report Posted July 5, 2009 I have a similar problem and i have checked all those things too and it still does it... Also the sub closest to the port get warmer than the other...shit is weird. It could be your enclosure maybe. Just my.02. yes! same thing going on here! lol its pretty...wierd i might try to get some wood into it i could probly get a little louder with a smaller box 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
