Alright, it's been a while since I've made an enclosure for anyone on the forums, but im back yet again to grace you with more sloppy enclosure builds :)
This enclosure will be for a 15" AQ HDC3. Specs come to 4.125 cubes net, tuned to 35hz, with 66 sq inches of port. I got a little started today, more tomorrow.
Getting the pieces cut..
Back going on..
Side going on..
Other side going on..
More tomorrow night :)
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
lookin nice man. moar pics
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
Team Tupperware
Thanks guys :)
And the clamps are Jergensen, home depot carries them for not too bad of a price...I'd suggest them, theyre nice clamps
Edited by Pioneer~Saturn
Team Tupperware
yep. i finished building my new box yesterday and used these same clamps.
i got a few 36" ones for $14 a piece.
the box looks good so far. very smooth and straight. i look forward to seeing this guy get finished!
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
^Thanks. And yea, I've got a good handful of the 36" ones but mainly like 12-14 of the 24" ones
Not much was done today due to my schedule and I had to run a bunch of wood to the shop to stock up and also to start making a couple work benches (and an island to do carpeting on)
But I got 2 of the 45 degree inserts cut real quick while I was there briefly
Little bit of wood :) (OoOoh, clamps)
Tomorrow I should be headed to the shop before work to get some work done and then i'll be working after work as well (and no work tuesday, so plenty of progress then :))
Team Tupperware
Port's 45 degree insert in..
Other 45 degree insert in..
Mock-up of the 2nd..
Was also doing a bunch of work for the shop today...tons of legs for workbenches being lined up and made :)
More tomorrow
Team Tupperware
