Help me fix my ground loop please
Jeff are your rcas grounded yet?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Yes, tried grounding the RCAs, made no difference to the sound brother. That was one of the first things I tried. When my ground was at the front battery, it sounded real bad, like rice crispies when I'd try to ground the RCAs. Now it makes no difference. I've quadruple checked every connection, made sure nothing's shorting, any audio wires that cross the power cables go 90 degrees to eliminate any RFI.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
you only have the one amp in the car right now?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
switched amps at all? im wondering if its the amp. or even tried powering a coax off the head unit to check that? internal amp defeatable? It may cause feedback if its fucked up.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I had some noise with my old amp also. Old amp is in my buddy's car and it has zero problems. On the Panasonic the internal amp is defeatable, and I did turn it off. Made no difference. I've tried three head units now.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
The only thing that totally eliminates the noise is of course hooking any of the head units to a separate power supply. I have zero noise that way. Even with a ground right slap dab on the same terminal that the amp is on (back battery), I still have alternator whine.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
What year and model vehicle? I installed
a Panasonic CQ- VD7003U in my 2008 Ram
and had same problem. My 2003 Dakota has
never had this problem. I got me a PAC SNI-1
ground loop isolator. Put it in back by amp and
my noise almost completely went away. PAC said to put
it in the dash behind HU. Noise completely gone for 1
full year now. The isolator plugs into RCA's inline between
HU and Amp. I didn't expect the results I got because
my alt. whine and interference noise was bad. You could
hear my doors open and close through my sub. I'd give
an RCA ground loop isolator a shot. If you have not already.
Edited by DownSouthCustom
The problem with most of the cheaper ground loop isolators is of course you lose a lot of your midbass, since that's what the frequency the noise is. It's a 1997 Pontiac Sunfire.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
Yeah I just have my sub amp wired in the Ram. Going
for SQ in this being daily driven so bout to hook up my 5
channel and my 2 channel so I will be dealing with this again
next week. Gonna keep watching post cause for SQ gonna
need my mid bass. Sorry no help to you but thanks for
letting me know that Im gonna have to deal with this BS
too. If you figure it out please post. Thanks
  • Who's Online   1 Member, 0 Anonymous, 1452 Guests (See full list)
