Hi how would you re cover a dash that has been in the sun to long, so its got cracks ... now would i have to sand it down then cover it with fabric or wat? pls help...
You can always fiberglass it but that may be a pain in the ass for you if you have never fiberglassed before...Hell, it will be a pain in the ass, period!
But yeah you can fiberglass it.
I plan on covering my dash because the insert I purchased to accomodate my headunit was at one point matching my interior and now it's not. I'm going to use suede and see if I can get it on so that it will still clip back in. You may want to try first, but I plan on buying some cheap felt that is about the same thickness as the suede so that I don't spend 8 bucks a yard for nothing.
THANKS man but im in south africa so ill do the fiberglassing... NOW would i have to strip the old stuff already on the dash off? and then apply the fiberglass?
Yes richie. Strip everything off first, then lay like 2-3 layers and soak it in resin...Sand it down and use some formula 40 spread over it. Start sanding lol.
If your stuck, hit me up at SnS
then im rambo bitch
YO watsup man!!! thanks for the tips!!! will do if i have questions thanks.
no probs man
then im rambo bitch
