Berto Posted July 15, 2009 Author Report Posted July 15, 2009 (edited) I had been thinking about a port throught the back, behind the rear headrest but the tank. Is either blocking an are or it has wires blocking the are. And I don't know about relocating the fuel cell yet, I'll have to look for a spot to put it. What would be the main proble with the fuel cell being there? I'm thinking I could blow shit up but what is the real problem? Edited July 15, 2009 by Berto Quote TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
capalass23 Posted July 15, 2009 Report Posted July 15, 2009 custom doors is the best way to do this Quote 95 WAGON BUILD FEED BACK
Boon Posted July 15, 2009 Report Posted July 15, 2009 Jags are a bitch like that. Usually no problems with bass affecting the tank but getting noise into the cabin can be tricky, especially where I live because you can't cut the tray here. Glass a tube up to the factory 6x9 sub hole and do a 4th order... or cut a shiteload out of the tray and port through Quote 10.x volts fo' life!
Berto Posted July 15, 2009 Author Report Posted July 15, 2009 custom doors is the best way to do this Could you please explain? Jags are a bitch like that. Usually no problems with bass affecting the tank but getting noise into the cabin can be tricky, especially where I live because you can't cut the tray here.Glass a tube up to the factory 6x9 sub hole and do a 4th order... or cut a shiteload out of the tray and port through I though about the 6x9 hole but I checked and there was no stock 6x9's....and I thought about cutting the tray but there are wires on the under part of it I think. I'll try to get pics of different angles later today. Quote TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
Berto Posted July 17, 2009 Author Report Posted July 17, 2009 Here are a few more views from inside of the trunk And here are a couple views from inside the car I was thinking about cutting into the car from the holes on the inside of the trunk, but I don't know if that would be enough port area, or if that even leads to inside the car. And I'm not sure if there are wires in between the trunk and under the hard plastic behind my seats. Quote TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
mhuck123 Posted July 17, 2009 Report Posted July 17, 2009 Plenty of room, the wiring harness will not be a problem just cut the deck around it and as big as possible. My Benz is just like that and I had a lexus with the same thing. Build the box up against the tank and have the woofers fire up ports up. Quote Starting From Scratch!!
Berto Posted July 17, 2009 Author Report Posted July 17, 2009 Plenty of room, the wiring harness will not be a problem just cut the deck around it and as big as possible. My Benz is just like that and I had a lexus with the same thing. Build the box up against the tank and have the woofers fire up ports up. Do you think I should cut into the wholes that are right there already or cut around the wire harness area? Nice enclosure by the way. Quote TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
mhuck123 Posted July 17, 2009 Report Posted July 17, 2009 Do you think I should cut into the wholes that are right there already or cut around the wire harness area?Nice enclosure by the way. We cut everything out up to the wiring harness since its tucked away. Remove the cover on the top to make sure there is no wires but there rarely is there. Make sure to cover the gas tank and have a fire extinguisher ready just in case.....You want the hole as big as possible. Mine is 2 12's and the hole is big enough to fit the box through. My cars a lot bigger than yours but my lexus was about the same size, you get the picture. Quote Starting From Scratch!!
Berto Posted July 17, 2009 Author Report Posted July 17, 2009 We cut everything out up to the wiring harness since its tucked away. Remove the cover on the top to make sure there is no wires but there rarely is there. Make sure to cover the gas tank and have a fire extinguisher ready just in case.....You want the hole as big as possible. Mine is 2 12's and the hole is big enough to fit the box through. My cars a lot bigger than yours but my lexus was about the same size, you get the picture. I'm pretty sure I get it. Do you have some pics of your install from the inside though? Or do you have a build thread I could look at? Quote TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
mhuck123 Posted July 18, 2009 Report Posted July 18, 2009 I'm pretty sure I get it.Do you have some pics of your install from the inside though? Or do you have a build thread I could look at? No not on this one, didn't join the forum until it was already built. Looked almost exactly the same as yours though. Just cut a hole around the three that are there now face the woofers and ports up and you should be good. Quote Starting From Scratch!!
