I had been thinking about a port throught the back, behind the rear headrest but the tank. Is either blocking an are or it has wires blocking the are.
And I don't know about relocating the fuel cell yet, I'll have to look for a spot to put it.
What would be the main proble with the fuel cell being there?
I'm thinking I could blow shit up but what is the real problem?
Edited by Berto
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
Jags are a bitch like that. Usually no problems with bass affecting the tank but getting noise into the cabin can be tricky, especially where I live because you can't cut the tray here.
Glass a tube up to the factory 6x9 sub hole and do a 4th order... or cut a shiteload out of the tray and port through :)
10.x volts fo' life!
custom doors is the best way to do this
Could you please explain?
I though about the 6x9 hole but I checked and there was no stock 6x9's....and I thought about cutting the tray but there are wires on the under part of it I think.
I'll try to get pics of different angles later today.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Here are a few more views from inside of the trunk
And here are a couple views from inside the car
I was thinking about cutting into the car from the holes on the inside of the trunk, but I don't know if that would be enough port area, or if that even leads to inside the car.
And I'm not sure if there are wires in between the trunk and under the hard plastic behind my seats.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
Plenty of room, the wiring harness will not be a problem just cut the deck around it and as big as possible. My Benz is just like that and I had a lexus with the same thing. Build the box up against the tank and have the woofers fire up ports up.
Starting From Scratch!!
Do you think I should cut into the wholes that are right there already or cut around the wire harness area?
Nice enclosure by the way.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
We cut everything out up to the wiring harness since its tucked away. Remove the cover on the top to make sure there is no wires but there rarely is there. Make sure to cover the gas tank and have a fire extinguisher ready just in case.....You want the hole as big as possible. Mine is 2 12's and the hole is big enough to fit the box through. My cars a lot bigger than yours but my lexus was about the same size, you get the picture.
I'm pretty sure I get it.
Do you have some pics of your install from the inside though?
Or do you have a build thread I could look at?
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
No not on this one, didn't join the forum until it was already built. Looked almost exactly the same as yours though. Just cut a hole around the three that are there now face the woofers and ports up and you should be good.
  • Who's Online   0 Members, 0 Anonymous, 1340 Guests (See full list)
