puyallupn8ive Posted July 15, 2009 Report Share Posted July 15, 2009 I have a Kicker zx1000.1 and I wanna get 1 12inch L7 but I don't know if I should get the 2ohm or the 4ohm sub. If you have any advice it would help thanks. 98 Toyota Camry Eclipse AVN-6600 AudioControl 3.1 AudioControl Epicenter US Amps AX2000 US Amps MD-43 1 set Alpine type X components 1 set RF Power components 1 12" RE Audio XXX 220 Amp Iraggi Alt. Red Top (Front) Kinetic HC-600 (Back) Second Skin Damplifier Pro Link to comment Share on other sites More sharing options...
finkster Posted July 15, 2009 Report Share Posted July 15, 2009 you will want a dual 4 ohm and wire them to 2 ohms at the amp. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living Link to comment Share on other sites More sharing options...
kooch Posted July 15, 2009 Report Share Posted July 15, 2009 or the dual 2 and wire to 1 ohm........ Link to comment Share on other sites More sharing options...
enemyofsilence Posted July 15, 2009 Report Share Posted July 15, 2009 (edited) the zx1000.1 isnt 1 ohm stable iirc. its rated 1000rms at 2ohms. so the dual 4 and wire to 2 ohm you will be set Edited July 15, 2009 by enemyofsilence Team Bass-Hz Link to comment Share on other sites More sharing options...
tacomabanga1986 Posted July 15, 2009 Report Share Posted July 15, 2009 its 2ohm stable, if ur gunna run 2 subs get d2's n series parallel em to a 2ohm load, but for only one sub ied run a d4 wished some kicker amps were 1ohm stable, the only one i kno of is the sx1250.1 here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit Link to comment Share on other sites More sharing options...
finkster Posted July 15, 2009 Report Share Posted July 15, 2009 (edited) its 2ohm stable, if ur gunna run 2 subs get d2's n series parallel em to a 2ohm load, but for only one sub ied run a d4wished some kicker amps were 1ohm stable, the only one i kno of is the sx1250.1 theres more that run at 1 ohm. anyways, the OP said he only wanted one sub. He should get the dual 4s. and the amp is not stable at 1 ohm, so whoever said dual 2s should change their post so the guy isnt confused. Edited July 15, 2009 by finkster DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living Link to comment Share on other sites More sharing options...
puyallupn8ive Posted July 15, 2009 Author Report Share Posted July 15, 2009 you will want a dual 4 ohm and wire them to 2 ohms at the amp. Thanks I will be buying the 4ohm 1 98 Toyota Camry Eclipse AVN-6600 AudioControl 3.1 AudioControl Epicenter US Amps AX2000 US Amps MD-43 1 set Alpine type X components 1 set RF Power components 1 12" RE Audio XXX 220 Amp Iraggi Alt. Red Top (Front) Kinetic HC-600 (Back) Second Skin Damplifier Pro Link to comment Share on other sites More sharing options...
kooch Posted July 15, 2009 Report Share Posted July 15, 2009 theres more that run at 1 ohm. anyways, the OP said he only wanted one sub. He should get the dual 4s.and the amp is not stable at 1 ohm, so whoever said dual 2s should change their post so the guy isnt confused. its stable at 1 ohm been runnin my 1500.1 and my 2500.1 that way for a year and no problems. but they do draw a shit ton of power. i have a 250 amp alt. and a xstatic 4000 and a xstatic 3000 batt. again kicker might not be rated for 1 ohm, but they sure can take it. Link to comment Share on other sites More sharing options...
puyallupn8ive Posted July 15, 2009 Author Report Share Posted July 15, 2009 you will want a dual 4 ohm and wire them to 2 ohms at the amp. Do you think the CVX would be a better choice then the L7? 98 Toyota Camry Eclipse AVN-6600 AudioControl 3.1 AudioControl Epicenter US Amps AX2000 US Amps MD-43 1 set Alpine type X components 1 set RF Power components 1 12" RE Audio XXX 220 Amp Iraggi Alt. Red Top (Front) Kinetic HC-600 (Back) Second Skin Damplifier Pro Link to comment Share on other sites More sharing options...
cthedinger Posted July 15, 2009 Report Share Posted July 15, 2009 Do you think the CVX would be a better choice then the L7? go with the l7 If you have any questions PM me or Add me on Facebook CLICK ME! Shop at ct-sounds.com Subscribe to us on YouTube Link to comment Share on other sites More sharing options...
