Nice lookin install mang, and DAMN DO THOSE LITTLE AMPS ROCK!!!!
2 15"s Re-coned with a Custom re-cones with DD 9500 coils, Rockford Fosgate T1500-1bd, Designated Aux. 190 amp Alt@ 15.5 volts, Duel High Rate Aux. Batts. Doing 143+'s (current box and subs haven't been metered), 1st place in 129.9 Bass Race and a 2nd and a 3rd in NW DB Drag in the last two shows. Only gone two 2 show total thought, so not to bad
Thanks everyone well I guess its time to start building my amp rack I'll have pics when I get started and I will get a couple more vids before I add all 8 amps to show the difference
Under construction
soon to be:
2 DD Z9518's
8 lunar L1500's (500rms each)
Secondskin Dampner pro
250a Mechman rhino alt
4 runs of 2/0 (installed)
4 batteries (installed)
6-5 1/4's, 2-6 1/2's, 2-4in all ma audio (installed)
Nice job. If you're running those amps at 1ohms I'd be surprised if you're even seeing 500w each sub after impedance rise. Nonetheless nice numbers. We just sold our two 9515g's to upgrade to Z also. :)
those are some crazy tl numbers
Pretty decent for the power. Could we get one with the engine off, the car sealed up and the mic on the dash, just for reference sake?
10.x volts fo' life!
Thanks bro and im running them .5ohm right now the subs are D1's
Under construction
soon to be:
2 DD Z9518's
Yeah I can get those numbers for you just give me a day or two
Under construction
soon to be:
2 DD Z9518's
yo j im gunna get workin on makeing u a hub . so u can just plug and play instead of solder all those little wires.
4 Lunar 1500s
1 dd Z9512
mids and highs
2 Lunar 2200s bridge per side
1 set morel 6.5
Vifa Morel Lpg tweets
1 set morel 5.25
1 Lunar 255 center dif.
1 DD 5.25 coax center chan
