ok so in the next week or 2 im going to be wanting to get an amp to power my 4 12" Alpine type r's.... my budget is in the neighborhood of 200-300ish... i would really like to have an aq2200d or a hifonics bxi2008/2608 but let me know what you have... i need something in the neighborhood of 1800-2500rms@1ohm...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Check out zaxfire's sundown 1500d's they should put out a good 2000rms with good electrical.
I wouldn't go quite as far to say 2000 on good electrical. I've owned the 1500d's and ran them at .5 ohms. The most power I saw out of mine rms was 1850 or so at 1.25 ohms. The only way they MIGHT put out 2000 is if they were run at .25 and you could keep the reactive below .75 ohms. Then maybe but efficiency is going to drop into the 50% range there and probably won't make a ton more power than they do at .5 ohms.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
My bad i thought i seen somewhere they were underrated 500 watts still close.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
I guess 2000 would be possible with a MLA to keep voltage above 15 volts and a 300 amp ho alt along with a couple of big batts. Then yes I would say that you could see 2000 out of one.
Peak power they will do 2K, but rms is not that high. I've had the NSPL organization tell me that my amps were making 1747 watts each at 1.7 ohms. Jacob said that no way could a 1500d ever make 1747 watts at 1.7 ohms on 12 volts. It all depends on who is measuring power and how they're doing it.
1 XS Power D3100
Audio Control LC6i
Stock Deck
good info guys but lets keep it on topic.... anybody else?
3 Kinetik Hc2000's
Dual 200amp alts.
