CASZ71 Posted July 17, 2009 Report Posted July 17, 2009 Ok so I've been running my system's power wire to the aux spot on the fuse relay box on my truck for a while now and i was going to do the big 3 upgrade but then I thought about it and i would have to run 0ga to my fuse relay too.. Would it be ok for me to run 0ga to the fuse relay also? would it burn anything up? or should i even be running my power wire to there?? theres really no room on the positive battery terminal.. thats why ive had it to the fuse relay.. ive been told i would have more power goin to the amp if i run it straight off the batt.. but ive done it and my capacitor shows no difference.. 2000 GMC sierra 1500 ext cab KMC XD Spy series rims Front doors Fosgate punch 6 1/2's stock tweets Rear doors Fosgate power 4x6's Probox 10 and box under rear seat Rockford fosgate R-500 Prime series amp (537 rms) 4 gauge wiring
Stephen Posted July 17, 2009 Report Posted July 17, 2009 battery post extender, about $4 at autozone you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
enemyofsilence Posted July 17, 2009 Report Posted July 17, 2009 or you can use some buss bars coming out of the batt. more room to work with. edit: (in case you are wondering, this isnt me) Team Bass-Hz
CASZ71 Posted July 17, 2009 Author Report Posted July 17, 2009 But then if I do that Ill have to buy more wire also.. I just need to know if its ok to run it from there and if I could put 0ga to the fuse relay?? 2000 GMC sierra 1500 ext cab KMC XD Spy series rims Front doors Fosgate punch 6 1/2's stock tweets Rear doors Fosgate power 4x6's Probox 10 and box under rear seat Rockford fosgate R-500 Prime series amp (537 rms) 4 gauge wiring
enemyofsilence Posted July 17, 2009 Report Posted July 17, 2009 i have never had to work on a fuse relay... i just do the normal big 3. batt to chasis, engine to chasis, and alt to batt...i havent seen anyone add wire to the fuse relay for the big 3...but thats just me. Team Bass-Hz
lanman31337 Posted July 17, 2009 Report Posted July 17, 2009 or you can use some buss bars coming out of the batt. more room to work with.edit: (in case you are wondering, this isnt me) That is some of the scariest shit I have ever seen in my life. 2 - Audiopipe AP30001Ds 1 - Lanzar Opti Scion 600.4 4 - Lanzar Optidrive 1232D's 1 - Lanzar Opti 5.1 1 - Lanzar Opti 6.1 1 - Lanzar Opti 6C midbass 1 - Alphasonic PCT6551 1 - Lanzar VX830 1 - JBL 22 band EQ 1 - Lanzar SDBT75NU 1 - AudioControl Epic160
CASZ71 Posted July 17, 2009 Author Report Posted July 17, 2009 I could run the power wire to my battery but then I would have to reroute the wire.. buy more wire to do the big 3.. and buy and fuse and fuse holder :censored: .. so i was first gana try to make it work this way bc I have alot of wire (maybe 10 or 11 extra feet) with the setup now.. Ive got the amp right behind the drivers seat so its only about 5 ft to the relay.. If I could just run 0ga to the fuse relay I might have just enough.. if not then id have to buy more wire 2000 GMC sierra 1500 ext cab KMC XD Spy series rims Front doors Fosgate punch 6 1/2's stock tweets Rear doors Fosgate power 4x6's Probox 10 and box under rear seat Rockford fosgate R-500 Prime series amp (537 rms) 4 gauge wiring
