LT.Smoke Posted July 17, 2009 Report Posted July 17, 2009 Hey everyone i need to know what i could use as a spacer to put behind my sub ? Need something thats approximately 1/2" thick and relatively cheap to buy or make. What its for is im putting a new sub in my T-line enclosure and the new sub is 3/16" longer than the old sub so if i can get a half inch spacer it will fit in the box. The box is already tuned properly for the new sub just a hair to shallow is all. Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
brewer_brewer Posted July 17, 2009 Report Posted July 17, 2009 Hey everyone i need to know what i could use as a spacer to put behind my sub ? Need something thats approximately 1/2" thick and relatively cheap to buy or make. What its for is im putting a new sub in my T-line enclosure and the new sub is 3/16" longer than the old sub so if i can get a half inch spacer it will fit in the box. The box is already tuned properly for the new sub just a hair to shallow is all. your local shop should have sub rings made of 1/2, 3/4 or maybe even 1 inch mdf. if they don't then take any spare mdf you have laying around and make a spacer. i've made spacers out of 3/4 inch blocks of micarta i had laying around before (talk about sturdy). REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
LT.Smoke Posted July 18, 2009 Author Report Posted July 18, 2009 thanks bro for the quick response. Hopefully i can get it cut in the Am b4 i go to my show at 10am. Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
brewer_brewer Posted July 18, 2009 Report Posted July 18, 2009 thanks bro for the quick response. Hopefully i can get it cut in the Am b4 i go to my show at 10am. if you're looking to do it fast then cut out a 14 by 14 square (for a 12 inch, would be bigger or smaller depending on size of sub) and then the subs mounting diameter centered in the middle. then just screw that centered over your original hole and mount the electrostatic beat machine. or just cut a circle with the diameter of your subs overall diameter with the mounting diameter in the middle and sandwich it between the sub and the box (when i do this i recess the screws for the spacer a 1/16 or so and mount them offset of the screw holes on my basket) ^^^^^i usually put some sealant or wood glue between the spacer and the box just to be safe and seal it up. REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
Noobtastic14 Posted July 18, 2009 Report Posted July 18, 2009 ^^^^ Yup take a board, cut the mounting diameter of the sub on the inside and cut the outside larger than the outer diameter of the basket and joo set -Drew I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
brewer_brewer Posted July 18, 2009 Report Posted July 18, 2009 quick question. if you are looking at the bottom of the magnet of your sub, is there a hole going through it toward the dust cap? or do you have a pole plug (no hole going through magnet) if you DO NOT have a pole plug then DO NOT mount the motor to close to the port wall of your t-line. this will effect your sub performance. depending on the sub it usually needs to be AT LEAST 3/4 of an inch away from anything. REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
brewer_brewer Posted July 18, 2009 Report Posted July 18, 2009 ^^^^^^ incase your wondering why. it creates a vacuum/sealed type effect, mixed with the crazy cone movements that t-lines will do, it can make your sub either sound horrible, possibly rip spiders, bottom out, etc. so if this is the case then just add another spacer to pull the motor away from the wall a little more. i personally don't like mine any closer than 3/4 of an inch away from the wall REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
LT.Smoke Posted July 18, 2009 Author Report Posted July 18, 2009 it has a hole in the bottom the magnet going towards the cone. Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
