megaboom Posted September 12, 2006 Report Posted September 12, 2006 need help on deciding on a pair of 8's for my truck....... the choices are- soundsplinter rl-i 8 audioque sd-2 8 dd 10008a id 8v3 crystal comp8 might be a pair might be a single not positive yet probably goin in a 1 cu ft enclosure probably ported@ 35hz or so.thanks 2008 Black Chevy Tahoe -Murderedout/ 2/4 Belltech drop/26" U2-55's/ HID's in fogs and headlights/G5 tails1 - BC35001 - C1100.42 - SA ZV3 18's6 - 8" SA Neo Pro's2 - FT1-SE Tweets
spl audio1 Posted September 12, 2006 Report Posted September 12, 2006 i would definatley go DD but i hear good things about audioque good luck single cabs are hard to get a little loud i got mad and took out the back window put 2-15" in the bed firing into the cab
megaboom Posted September 12, 2006 Author Report Posted September 12, 2006 its not a reg cab its a megacab but thanks for the input! 2008 Black Chevy Tahoe -Murderedout/ 2/4 Belltech drop/26" U2-55's/ HID's in fogs and headlights/G5 tails1 - BC35001 - C1100.42 - SA ZV3 18's6 - 8" SA Neo Pro's2 - FT1-SE Tweets
2000LaDe Posted September 12, 2006 Report Posted September 12, 2006 the ID 8's i have heard great things about. check out the 8" challenge Lloyd and Sean did on CA. they will give u reviews of multiple 8" subs. check it.
spl audio1 Posted September 13, 2006 Report Posted September 13, 2006 ohhh so you are stuck with a prefab under rear seat box huh should look for woofers that require very small air space .25 .40 .50 most that have these will hopefully sound good in your space restraints
