Port Top or Bottom?
19 members have voted
  1. 1. Port Top or Bottom?
    • Top
      15
    • Bottom
      4
man your gonna have all kinds of opinions on what would be best. but huges said port on bottom if the enclosure is correct. the man knows his stuff. but in this case build it how you want it. if it doesnt work out for ya rebuild. you know how this game goes. build then rebuild then rebuild some more. lol
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
Well its done we will just have to see what it dose and if i don't like it i will redo it . Hay chris if you want to check it out hit me up on pm . thankz to everyone that posted
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz
19 cubes net 245sq in of port
Sundown 3500 @ .7 Ohm
Sundown 100.4
Rockford Fosgat Power Series
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
1 red top under the hood
2 yellow tops in back
big 3 with 1/0 knukonceptz wire
3 runs of +/- 1/0 knukonceptz wire
IT LBS
i'd rather have the port blocked then the subs.
No, you wouldn't.
The sub can displace air pretty much wherever you put it because it has a motor, but that port needs to BREATHE. If you obstruct the flow of air into or out of the port, then your effective port tuning will change to something you can't figure with a calculator.
All things equal, port on bottom should give you a little extra in the form of cabin gain (that's where the truck pushes the bass back) over a port on the top.
No, you wouldn't.
THANKZ
Sundown 100.4
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
IT LBS
  • Who's Online   0 Members, 0 Anonymous, 771 Guests (See full list)
