Enclosure Build: kerfed ports, dual 12's
This enclosure is for a pair of square Atlas 12's and the specs come to:
-4.31205 cubes net
-32.26Hz tuning
-76.5 sq inches of port
Posted Image
Posted Image
Getting started (sorry about all of the reall crappy angled pictures...my camera's screen is busted and I just have to aim it the best I can and just guess what im taking a pic of)
Posted Image
Posted Image
Kerfed pieces getting going:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Posted Image
Corner inserts..
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Team Tupperware
Port extensions cut and going in..
Posted Image
Posted Image
Posted Image
Inserts for those..
Posted Image
^not mounted yet, just mocked-up
More later..
Team Tupperware
Thanks guys, and im not sure what kind of power is going to them :(
And thanks for the comment on the AQ box...suede was a bish tho to wrap, especially the emblem :(
Team Tupperware
I must say that is an awesome looking box, I am really into the way you curve the MDF, i have never seen anything like it. I just have a question and it may be a dumb one, but when ever you make those rounded bends in the MDF, how do you know what distance to put between the lines and how many lines are needed to complete the required length you are trying to achieve?
Build in progress:
Kenwood DNX890HD
Rockford Fosgate White wolf RCA's
2 Rockford Fosgate T400.4 on RF fanatic q components (6.5 in the kick, 6.5 in the front doors, 5.25 in rear doors)
2 Rockford Fosgate T2500's on sub
1 Fi car audio Team 15 D1
XS Power D3400 and three D975's in the rear
Mechman Elite 370
Stinger power connections and cable
Great looking box man!!
kerfs are no joke :good: keep teh pix coming
-Drew
uhoh_45 said:
Thanks.
As for the curves. I model it out on Sketch-Up and see where the straight lines of the panel start and stop for that kerf and mark on the boards where the cuts need to start/stop..
Then I started cutting every .5" until I get to the other mark on the board, unless youre doing extreme bends then this is plenty. Now, if you want to have perfect kerf widths that bend together seamlessly, some math is invloved.
You would have to subtract the inside radius of the curve on the board (on Sketch-up) from the outside radius and find the difference between the two. Then you would have to devide by your blades width...then this number would be the # of cuts you'd need to take away enough material for the bend to be possible...then do the math for the spacing needed between each cut to get that # of cuts within that space evenly. It's more work, but if youre a perfectionist, that'd be the way to do it..lol
Team Tupperware
