Optima vs Capacitor?
You said you installed your setup yourself right? You can do it, not any more difficult than that. The hardest part for me is getting the wire routed just where I want it. A little case of OCD kicks in. haha. There is a thread stickied here in the forum on how to do it.
So I guess I understand the concept of the thicker wire but i dont understand how the same amount of power cant go through 4 gauge. Also what should you use for a size of the subwoofer wires. I have some pretty small wires going from the subs to the amp.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
Check out this thread. Click Here
Good info in there.
and would there even be a point to doing the big 3 without upgrading from my 4 gauge power wire and ground wire?
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
Would prob help somewhat. Look to see what size the power wire is coming from your alt now.
Gonna go for now. keep us updated in what you decide to do.
alrite ill check that out . Thanks for all the help man i appreciate it.
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
aux tray from the Duramax Diesel and a XS power D3400
So am I shorting myself by having small wires going from the subs to the amp? i think it may be 16 gauge or maybe 12
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
and i just noticed, I only have an 80 Amp agu fuse on my power wire, is this bad? Its all that came with my installation kit
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
12 g is sufficient 10guage is better . in my silverado Ive got a Napa Orbital in the main location then the XS Power in the Duramax tray 1/0g wire between the 2 .1 run of + one of negative. then 1 run of each back to distro blocks and that is 1/0g as well which powers 2 channels off of an SAX-100.4 at 4 ohms each and an orion 2500D at 2 ohms no big 3 so Im still with the small factory wireing for the ground and all under the hood and I barely get a drop and thats going by the same guage you are. the orion is rated at I believe 1700 watts at the load Im running at with impenence rise and this is just a guess Im probably seeing 1000 watts Id assume
so what about the 80 amp fuse?
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
