What do yall think about this?? will be going in my single cab 95 dodge ram
here are the particulars....
bottom 77 x 49
bottom 77 x 49
top 77 x 49
top 77 x 49
baffle 74 x 46
baffle 74 x 46
front 46 x 5
front 46 x 5
side 77 x 16
side 77 x 16
side 77 x 16
side 77 x 16
Port internal sides (4) 3 x 9.5
port external top 44.5 x 3
port external bottom 44.5 x 6
port external sides (2) 3 x 9.5
we are looking at 10 sealed and 17.75 ported
get dowels for bracing...
46x10 for the cutout to cab
10-11 feet of wood dowels for bracing...
i mean the dowels are 12 inches apart
fiberglass resin first then cover in bedliner... also resin the corners and dowels on the inside
so it'd be easiest to build the port outside the car
then slide it in
then screw it in from the sides
3/4 MDF sheets
its 5T x 19W >>>> PLEXIGLASS WINDOW
now make sure the inner lip is .5 bigger so you can flush mount the plexi on the inside.
like in the pics.
:hairtrick:
DOOOO EEEET ;)
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
<------will be waiting ;)
Wiring-Memphis
i thank you sir :)
Wiring-Memphis
Little of topic but is having the subs facing up and down the only way to do 4 18's? I want to do 4 but am partial to the series tuned compression chamber but don't know how it would work because I will have to tilt the subs to fit them in the bed.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
yeah the only way would be to tilt them i have like 19 1/2" on the height in my bed and it still wasnt enough
but would that work with the middle chamber basically being a trapezoid instead of rectangular?
  • Who's Online   0 Members, 0 Anonymous, 1016 Guests (See full list)
