MaX Posted July 31, 2009 Report Posted July 31, 2009 ok so I'm thinkin of adding another AQ 2200D to my DC Level 4 xl AQ amps daisy chained are rated for around ~4000-4400 wats at 2 Ohms...problem is that the xl is a dual 2 so would you guys think it would be ok to run them daisy'd at 1 ohm? <div align='center'>03 RAV4 18" DC Level 4 XL Knukonceptz 1/0 gauge AudioQue 2200D 6.25 cubic foot box tuned to 32 hz DB Linc 200 Amp H/O ALT 1/0 BIG III</div>
JPagan Posted July 31, 2009 Report Posted July 31, 2009 4,000 watts is too much for a XL to run on daily.
MaX Posted July 31, 2009 Author Report Posted July 31, 2009 I'm pretty sure that someone on here said that they have ran around 4000 daily <div align='center'>03 RAV4 18" DC Level 4 XL Knukonceptz 1/0 gauge AudioQue 2200D 6.25 cubic foot box tuned to 32 hz DB Linc 200 Amp H/O ALT 1/0 BIG III</div>
Got_Bass89 Posted July 31, 2009 Report Posted July 31, 2009 Strappin the amps @ 1ohm? So running .5 each? on a XL? Passport Build Here Alarm: Prestige APS997A 2-Way/Remote Start HeadUnit: Pioneer DEH-P6000UB Front Battery: Yellowtop Optima D34/78 Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH Subs: 2x DC Lv4XL 18's Amps: 2x Sundown Saz1500's Strapped Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube) Pillars: AudioBahn AS31Q Front Doors: Clif Designs TX40.5 Back Doors: Clif Designs CD50.4C Rear Speakers: Clif Designs TX46.5 Front/Rear Amp: Kicker ZX350.4 Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4) Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
MaX Posted July 31, 2009 Author Report Posted July 31, 2009 i might be having a bit of a brain let down here haha, but AQ says that a pair of 2200's have full potential at 2 ohms daisy'd...my XL is dual 2...so my only options are 1 or 4 ohms <div align='center'>03 RAV4 18" DC Level 4 XL Knukonceptz 1/0 gauge AudioQue 2200D 6.25 cubic foot box tuned to 32 hz DB Linc 200 Amp H/O ALT 1/0 BIG III</div>
oldschool Posted July 31, 2009 Report Posted July 31, 2009 you can run 4000 watts daily i did and then some but you have to adjust the box for that much power however i would just run 1 amp but i would not run both strapped at 1 ohm daily 1st reason you have to have a very strong electrical 2nd that would be more than 4000 watts at 1 ohm strapped. TEAM GROUNDPOUNDERS INC. 156.5 OUT THE TRUNK OF A 95 CADDY W/1 SUB & 2AMPs score done on a termlab mic in the kick on the dash sealed was 154
creyc Posted July 31, 2009 Report Posted July 31, 2009 Not only are you asking a LOT from that Lvl-4, but you're gonna need a very strong electrical system to back the amps at that impedance. Have you measured your impedance rise? I'm guessing you'll be fine running them at that impedance after rise, if you're EXTREMELY careful, for both the subs and the amps sake. Warranty won't help you if you fry the amps trying to play some real low frequencies where impedance rise drops to nothing in your box and the amps start clipping to put out power just before they start smoking. At which point your sub will start smoking as well, because any clipping at 4400 watts is gonna roast that sub. In short, with experience and much care with plenty of juice it could be done. I have a feeling such might not be the case... 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck
mr.p Posted July 31, 2009 Report Posted July 31, 2009 if your dual 2 just run one amp per coil. then later on get another xl. but yes i have run 4kw daily. box choice is very important. DCAUDIO BALLS DEEP
