lol let me jump in here guys and give my opinion on something. why should i use two different meters to measure the results when i have the volume the same, bass knob the same, RPM on truck the same, and playing the same 40hz tone. what is gone be different from clamping the + wire, then going and meauring the +- wires together.
so, i know i read the 1/0 that was stupid, but with the other reading i think they are right and i think its kinda pointless to use two different meters at the same time. what is going to change between me doing the two readings? just my opionion, dont take it wrong but if anyone kinda think of a good reason to use two meters let me know. otherwise im doing just one
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
So you measured one burp to get the AC voltage and a seperate burp to get the AC current? If so there's nothing wrong wtih that. I've done it myself and then measured with two meters at the same time and there was only a 47 watt difference between the two calculations. I can tell you why there was the difference too, because of the loss of voltage after the first burp. The second burp didn't produce as much as the first and there was a little less power made. Unlike when measuring with both meters at the same time you won't get any loss in a second burp. You're good doing it this way, just remember that your probably making a little more power than what your calculating. In this case I'd say that you are probably over 800 watts and your rise is going to be a little less then what it is too.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
ok cool. and yes that makes since with the meters. i guess if u are really needing to cut it close, thats a good way to go. but im just a street beater and hit up comps when i can so its all good. ill be doing some more readings this week just to double check myself. thanks for all the input from everyone.
mike
audioque 10'' HDC3 owner
1 3500d AQ amp
did you clamp the + and - the get the voltage or did you use the leads
to get voltage i used the leads on the + - wire. to get amps i clamped the + wire. just did it at two diff times with same 40hz burp
1 3500d AQ amp
ok. thats where the confusion came in. earlier you said you clamped them. and yes what nightshade said is correct about doing them at different times. but the way you put the info in your earlier post was that you just clamped them. thats why i said what i did. i was just taking what you said as literal. and he was correct when he said you use it as an expression.
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
If you don't mind me asking what amp was this anyway? 800 + watts at 4 ohms is pretty decent. Just think, if you can wire it down lower than you have it now I'd bet that you'll see at least a 2 db gain.
1 XS Power D3100
Audio Control LC6i
Stock Deck
http://www.stevemeadedesigns.com/board/ind...showtopic=23462
Try this link but read through the whole thing. It should help alot.
I'm out working on the truck so I won't be in for to long.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
