Everytime I try to log in it gives me "user profile service failed logon user profile cannot be loaded" Ok, can't figure out how to fix it. So I tried to make a new user and it won't create a new user from the guest account because its not administrator. So it asks for my admin password, but my admin profile is broken so the password doesnt work. Can i manually create a new administrator profile?
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
bump?
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Proceed at your own risk. Basically, if you FUBAR your computer, its your own damn fault.
If you can, log in as another user, back up any necessary data.
Go into safe mode and system restore. If that doesn't solve the problem, then chance are, you'll probably have to reinstall Vista.
Not that big a deal if things are backed up. Take this as a prime example of why critical files should ideally have multiple duplicates. And why doing day to day computing with admin privileges isn't the best of ideas.
Also, after either one, MAKE ABSOLUTELY SURE you check for Windows updates. Either option will likely uninstall all/a couple of them.
I do realize this can sound elitist, but that's not my intent. Read my sig.
linky
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Just another reason to add to my list of reason's to not use Vista anymore. Now if only I could figure out linux.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
Because corrupted files is only a Windows problem. Troll-B-Gone.
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
No, but it does seem to be worse on Vista. I'd like to go back to XP, I love windows myself. But I don't like Vista. Maybe the next windows OS will be better.
15.4" widescreen
What it does:
linky
Yeah I already tried that before I posted the topic, I was just trying to avoid a reformat. System restore will not work unfortunately, it just fails every time.
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
