Gocartnut95 Posted August 3, 2009 Report Posted August 3, 2009 I got a 1990 bronco and i know your not suposed to run the power and RCA's near eachother but what about the REM. wire? can that be with the power? seeing as its is power in a way anyways... Thanks, Ryan
CASZ71 Posted August 3, 2009 Report Posted August 3, 2009 Shouldnt hurt anything.. mine are right beside each other and i have no problem 2000 GMC sierra 1500 ext cab KMC XD Spy series rims Front doors Fosgate punch 6 1/2's stock tweets Rear doors Fosgate power 4x6's Probox 10 and box under rear seat Rockford fosgate R-500 Prime series amp (537 rms) 4 gauge wiring
Torres Posted August 3, 2009 Report Posted August 3, 2009 correct. both are carrying a DC signal, the remote wire is just much smaller. the RCA carries a signal to the amps. i did a power/remote run together yesterday in a car and it's fine. just keep RCA's away and you're good
Gocartnut95 Posted August 3, 2009 Author Report Posted August 3, 2009 correct. both are carrying a DC signal, the remote wire is just much smaller. the RCA carries a signal to the amps. i did a power/remote run together yesterday in a car and it's fine. just keep RCA's away and you're good Alright thanks alot! :]
SQMonte Posted August 4, 2009 Report Posted August 4, 2009 I got a 1990 bronco and i know your not suposed to run the power and RCA's near eachother but what about the REM. wire? can that be with the power? seeing as its is power in a way anyways...Thanks, Ryan Yep, no problem with that, power cables on one side, signal cables on the other. Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
