currently in the process of doing primer on truck for paint, while i am im going to set up the rear for my wall which consist of 12 re 12" subs. attached is a few photos, i dont know where to use my e dead deadner or just screw/ glue a piece of mdf to the rear wall and then fill it with foam. what would you all do?
what wall will look like
the hump in middle is where mdf will stop, will come up from floor and mount flush and then at top i would fill it all with foam.
Deaden it then MDF it then foam it :)
X2 - your sheetmetal would still resonate, deaden it :dj:
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
deaden it til you thing you have gone overkill then double it. Foam is nice between wood and metal too.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
  • Who's Online   0 Members, 0 Anonymous, 1197 Guests (See full list)
