qu1cks1lver56 Posted August 5, 2009 Report Posted August 5, 2009 is 1/4" thick copper flat bar thick enough to make a busbar out of? i found some cheap and it'll be cheaper than buying some distribution blocks. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
98crewcab Posted August 5, 2009 Report Posted August 5, 2009 is 1/4" thick copper flat bar thick enough to make a busbar out of?i found some cheap and it'll be cheaper than buying some distribution blocks. I dont see why not, would be a little worried about corrosion, but polish it up real good, make up all your terminals, and spray with a corrosion resistant (like for your battery posts) think aluminum would do better as far as resisting corrosion, but if you have a good deal on copper...... 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk!
Pioneer~Saturn Posted August 5, 2009 Report Posted August 5, 2009 I have 4 copper busbars in my car (1.25" x .25" thick), all of them with threaded mounting points and theyre great. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
qu1cks1lver56 Posted August 5, 2009 Author Report Posted August 5, 2009 theyre silver coated i believe, will that help with corrosion? First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
Pioneer~Saturn Posted August 5, 2009 Report Posted August 5, 2009 Lol, mine are as well. And yes, it's there to help protect from corrosion. But I would still coat them in some kind of connection protectant after you mount all of your mounting points to it. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
qu1cks1lver56 Posted August 5, 2009 Author Report Posted August 5, 2009 alright, thanks for the info. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
