headshok Posted April 4, 2007 Report Posted April 4, 2007 Hi guys, ok i noe this is a dumb question, and also most pple don like capacitors, but i need to know. From what i understand, to wire up a capacitor, assuming u have a 2 amp system that both amps run off the cap. from what i know, here's how the wire should be ran: 1)battery to capacitor (+) 2) capacitor (-) to chasis 3)another wire from the cap (+) to a fuse distributor block and then from the fuse distributor block, to the amp+ and etc. am i rite? case no2 here's how most of the pple here wire up the capacitors. Assuming a 2 amp system to be run off the cap too. the fuse dist block is a 1 input to 3 output one. 1) battery to fuse distributor block 2) output 1 and 2 goes to the respective amps 3) output 3 goes to the capacitor, and capacitor is grounded to chasis. Now, for case no.2, the cap will still power up, but will it function properly? i have yet to come across any wiring tutorial online that states it lie that. my stand is that, if u wanna use a cap in the system, put it either b4 the fuse blk (if its powerin both amps) or b4 the amp, but not at an output of the blk. What do u guys think Cheers Russ Shok Industries Feel the POWAAAAAAAAAAAAAAAAAAAAAA!! Competition SQ Car install by Dimension Audio Singapore http://www.stevemeadedesigns.com/board/ind...showtopic=65190
Slinky Posted April 5, 2007 Report Posted April 5, 2007 I dont think it matters, as long as you have the + of the cap with the +of the batt and amps and the - to the ground. DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
