98HOEONSIXEZ doing a build???Measurements/pics in..pg3 come help!
Ok in this first picture,i measured about an inch and a half off the back wall to about 2 inches away from the back of the seat and came up with 19-20 inches.Also i dont know if you can see it in the picture there is a ledge that comes out from the back wall that is about 3 iches higher than the rest of the floor,it extends out from the back wall to about ten inches then it drops down and levels out for the rest fo the floor
Posted Image
The next one i measured was about 1.5 inches from the back glass to the back of the seat and got right at 10 inches
Posted Image
This one is measured from close to the floor up the back of the seat so this would be the front face height
Posted Image
This one is from side to side on the bottom.
Posted Image
i agree with exposport on a lil more port area.
i dont have any programs to help with designs or i would.
i think a box like BASS14's would be a good design though.
subs firing forward on passenger side, port up on driver side (get ur lean on).
ill look for his build link.
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
Heres a few more pictures i took.
this is the ledge that i was talking about,its about 3 inches tall
Posted Image
This is the height from the top of the ledge up the back window
looks to be about 24-25 inches to the back window line,but again it can go higher if needed too
Posted Image
This is how long that ledge is
looks to be about 7-8 inches
Posted Image
If all yall think more port would be good thats cool with me...id like to do a sub behind each seat,and one big port in the middle
I knew you were good for something LOLS ...thanks man!
take a grinder or something, and cut that bracket off on the back wall, i did that with mine, you gain at least another inch!!!
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
just build a false floor infront of that hump so everything sits nice and flat.
^^^that also give you a place to put things, ie: wire, crossovers, fuses, etc.
  • Who's Online   0 Members, 0 Anonymous, 1028 Guests (See full list)
