Ok lets try this again. I'm building another T shaped console box very similar to the last one but stronger!!!
Yeah I have some 3M weatherstripping to put on the mounting feet. If I see that it is causing a problem I will put it back under the seat.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
Got some more work done yesterday. Carpet dried out and I got it put back in.
Posted Image
Posted Image
After hours of fighting it I finally got the box in. The next time I attempt something like this I'm going to build in the truck, because I got the box in a bind trying to get it through the door and almost broke it, but its in there now and I dread my next rebuild because I'll have to wrestle it back out lol.
Posted Image
Also made a little video when I installed the deadener. nothing at all really just the difference that the damplifier pro can make.
http://vids.myspace.com/index.cfm?fuseacti...ideoid=62046652
You ever get it installed? If so, how does is sound?
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
Got everything hooked up and the box=fail!!! :( It is loud as hell and destroys the interior of my truck but I have this awful sound from somewhere in the box. My guess is that it has to do with the troubles I had with sealing the top down. I cant find where exactly the sound is coming from. I am going to build another one. Next time I will just build a small beauty panel for the top to eliminate the problem. I'm pretty bummed right now and since I'm so busy at work it will be a while before I get to rebuild so no beat for a WHILE. Prolly gonna get a table saw before I try it again.
is it like a bad seal noise, or port noise. if you think its a bad seal somwhere just run you hand around the box to find it and use some ducktape to seal it maybe
justin smith
1996 mercury grand marquis
20'' bentchi b7 lexani n3000 245/35/20
cactus 5kw at 1ohm dcr(beast)
2 18'' btl's in a 14.15^ft wall tuned to 35hz with 210'' of port
kicker zx650.4
componets in still the works
200amp motorcraft alt
xs power d3100 (beast)
kenwood ddx512 h.u.
you mean my EX? the one I dumped? just remember every time you kiss her that i used to cum in her mouth
and BTW your girl just called me....
pure pwnage
It sounds like wood clapping together. Its on the opposite end of the box from the port. Never built a box that didn't sound good... Next time structure first, pretty second. The next time I will fiberglass as I go like I have done before and make sure its damn strong then worry about cosmetics.
hell just check and see if you can find the crack then take the nozzle of the of youre wood glue run it down the crack and glob it up in the crack and try to seal it cause the box is sick with the sub inverted like that itll be a cheaper fix then tryin to build a new box
justin smith
kicker zx650.4
kenwood ddx512 h.u.
pure pwnage
  • 1 month later...
Ok so I'm finally getting to rebuild. Will have a few pics up tonight. Got the top and bottom cut out working on the back and got a call so I figured I'd take a break and come in and let you guys know what I was up to.
Got everything cut today. Attached the back top and bottom and started some glassing.
