drill batter tap it to the amp out- speaker wires, which ever one doesnt pop, is the blown one
Or depending on how its wires, you will have to go to each one
i have 8 subwoofers..
and something blew today.. how can i found out which one blew?
Put a multimeter on the ohm setting on each voicecoil. If one goes to Inifnity, it's blown.
Current: Two old school Orion HCCA 12's, No amp currently. Did run DAT Hellfire Prototype.
Old set up: Orion 2NT 15", Logic Soundlabs GSX32D,
press on each sub n see witch one doesnt move?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
play a 60hz test tone at a decent volume and use a strobe light set at 60 hz, it should make them appear to stop moving at a certain position (out, or in, or somewhere in the middle, but it should trick your eye into seeing it not move, kinda like a timing belt light)
theoretically the blown one should be at a different degree phase, or not moving at all(which I assume isnt the case)
Team DC
holy shit I want to try that now well not the blown part but that would be sick.
anyways back on topic how do you know something is blown?
because if you knew one of them was blown couldn't you tell which one it is?
Wouldnt be thehoe92 without teh purple
sometimes you just notice the db decrease...I knew when a single coil of my dvc cvr's blew back in the day because it didnt seem as loud, since the one woofer was now 4ohm instead of 2
Team DC
The strobe light deal would work if he is playing any music at all, I think based on how its wired, he has no sound at all, and Iam thinking he is worried its either the amp, or subs- maybe no bass at all? What I'am guessing
haha tibs is just like me I get worried and post up the question/problem and then go work on it and come back and read all of what I just did.
so he is probably out at his truck right now figuring it out.
after i posted this i was playing around with it..
and definably can tell it wasnt a speaker.
it was the box. the supports inside 3 of them that go to the back wall came loose..
its fixxed now.
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
  • Who's Online   1 Member, 0 Anonymous, 747 Guests (See full list)
