Rofkford Amps Old school vs new ohm loads
Hotdog
I am specifically talking about the 10001bd amps here.. I was wondering why the old school Power 10001bd amp put out 1000rms at 2ohm and the new Power 10001bd puts out 1000rms at 1 ohms?
Is there less of of power draw on 1ohm vs 2ohm?
doesn't a 2ohm load run cooler then a 1 ohm load?
I just wondering why they went from 2 to 1 on there design.
a 1 ohm load run less effecient than a 2 ohm load and in theory will run hotter, but not by enough that you would be able to tell the difference.
if you have a 1 ohm stable amp it gives you alot more choices for power and different vc subs you can use.
instead of just having a 2 and 4 ohm load to choose from you now have 1,2 and 4.
edit: ^^^^anywhere from 1 to 8 ohm actually ^^^^^^^ :spiteful:
So based on that I could assume that the older Rockford 10001bd amp that run there rated power at 2ohm is a more efficient amp then the newer ones that run there rated power at 1ohm?
http://images.cardomain.com//products/roc/ROC1000BD_1.jpg
these^^^
http://outlet.crutchfield.com/p_675FRP1000...1bd.html?tp=115
or these ^^^^
the new ones are more effecient. the old ones got hot as shit
^^^those are good amps and put out solid power but they aren't as effecient as the new ones and tend to get a lil warm.
i have one on my lvl3 15 and it dont get hot at all its running just below 2 ohm????/and to boot it putting out 1k and isnt drawing more that 60 amps at full tilt i dont think the new ones can do that and its half the size...
JAMES SAID..
you dont need 1500 for a WOOFER people just love overpowering rather then building for the power recommended
THATS A SMART GUY...
technically you are comparing 2 separate amps.
1 is the punch series (newer)
and 1 is the power series (older)
the power series amps were designed to disperse more heat with a larger heat sink therefore increasing efficiency.
the punch series, all though it still puts out, will not run as cool in the same situation.
I have always learned that a 2 ohm load is less stress on electrical compared to a 1 ohm but it is a wiser buying decision to get the 1 ohm stable for greater wiring capabilities.
Wouldnt be thehoe92 without teh purple
no.. I am comparing power series to power series.
2007 model T10001bd vs older Power 10001bd
so will the 1000rms at 2ohm pull less amps then 1000rms at 1ohm
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
