Yea thats the proper way of doing it so you dont run into any issues but with my old JVC it happened while driving, so how do you explain that? :unsure: Someone should make a sticky about this for future reference, for those that are new to installing :)
Car - 99 Neon Sport
Batt - 1 Redtop up front On 200A Excessive Amperage alt
Sub - 2 12" Kicker L7's in ~2 cuft @ 36hz each on a Xtant X1001 @ 1 ohm
Front Highs/Mids - JVC CS-FS6 and Infinity 6022i on Xtant A2002
Rear Highs/Mids - None
HU - Pioneer DEH-P8600MP
1/0 wire ran thru entire car aswell as big3
DB - 144.5 @ Dash.
Strip back a piece of wire and wrap it around the outside of the rca outputs on the back of the radio. Make sure its touching the metal (ground part)or the rca's. then ground the wire to the chassis ground or antenna
99 suburban, ranger rover headlights, SS front bumper,roll pan with frenched tag, 2nd row delete,glassed dash..audio to come whenever I figure out what I want.
Always make sure the GROUND is the Last thing disconnected from you amp is what i have always been told. AS well as the FIRST thing hooked up. The Ground on any Electronic item is VERY important. I have seen a lot of "problems" caused by a bad ground. In my blazer i had to actually Run a new ground for my H/U so i wouldn't pick up hum from my Headlights and Blower motor. Not all Vehicles Need this just saying.
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
