siucsaluki11 Posted August 12, 2009 Report Posted August 12, 2009 So tomorrow im doing my first box with kerfs if all goes right. As far as reinforcing the kerfs what do i use? Resin, glue, resin or glue with sawdust...? And where can i buy resin? Im going to Menards tomorrow morning to pick up wood and supplies needed. Any suggestions as to what to buy? woman..cant live with em...cant shoot em...guess were all fucked You might be a Redneck if you use your leftover gutters for a speaker box port... YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
98crewcab Posted August 12, 2009 Report Posted August 12, 2009 So tomorrow im doing my first box with kerfs if all goes right. As far as reinforcing the kerfs what do i use? Resin, glue, resin or glue with sawdust...? And where can i buy resin? Im going to Menards tomorrow morning to pick up wood and supplies needed. Any suggestions as to what to buy? you can just glue them in. I would only add fiberglass and resin if this enclosure is going to be HUGE. : 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk!
Boon Posted August 12, 2009 Report Posted August 12, 2009 If you want it to be rock solid, resin and rock the box as the resin cures. Maybe even throw some glass on the inside of it. 10.x volts fo' life!
