Demo402 Posted August 12, 2009 Report Share Posted August 12, 2009 Can anyone post the diagrams for wiring 2 dvc 4ohm subwoofers to a mono amp that is 2 ohm stable. i know theirs series and parallel but not exactly on the way there both wired! Thanks! -Ryan Quote Honda Accord 4 Door Current System - (2) 12'' Mtx Thunder 5500's (1) Alpine Mrp-m1000 @4Ω (1) Pioneer Deck Deh-3500 (1) American Legacy 1.0 Farad Capacitor (1) Stinger Voltage Meter (Blue) Big 3 Knu 1/0 Box 3.4^3@37hz Youtube. Link to comment Share on other sites More sharing options...
CaptainzPlanetz Posted August 12, 2009 Report Share Posted August 12, 2009 Can anyone post the diagrams for wiring 2 dvc 4ohm subwoofers to a mono amp that is 2 ohm stable.i know theirs series and parallel but not exactly on the way there both wired! Thanks! -Ryan You can only get a 1ohm load or a 4 ohm load http://www.the12volt.com/caraudio/woofer_c...sp?Q=2&I=42 You could wire it to 1ohm and impedence rise and box rise should put it over 2 ohms, but still be careful about it... Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members. Link to comment Share on other sites More sharing options...
DEEz NUTz Posted August 12, 2009 Report Share Posted August 12, 2009 Can anyone post the diagrams for wiring 2 dvc 4ohm subwoofers to a mono amp that is 2 ohm stable.i know theirs series and parallel but not exactly on the way there both wired! Thanks! -Ryan www.rockfodrfosgate.com "wiring wizard" Quote 153.3 @ Turkey Drag 2009 Spl Modified 1001-2000 - Derrick Jones my alias... Wudn't accept DEEz NUTz !!! Link to comment Share on other sites More sharing options...
swat281 Posted August 12, 2009 Report Share Posted August 12, 2009 look up rockford fosgate wiring wizard that will have what u looking for Quote Link to comment Share on other sites More sharing options...
swat281 Posted August 12, 2009 Report Share Posted August 12, 2009 (edited) X2 Edited August 12, 2009 by swat281 Quote Link to comment Share on other sites More sharing options...
98crewcab Posted August 12, 2009 Report Share Posted August 12, 2009 (edited) couldnt get it to upload right, check rockford fosgate- they have all the diagrams and calculators.... EDIT- sorry, fugged that one up- where was I? lol Edited August 12, 2009 by 98crewcab Quote 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk! Link to comment Share on other sites More sharing options...
Demo402 Posted August 12, 2009 Author Report Share Posted August 12, 2009 Thanks for the help guys, i had no clue that Rockford Fosgate had that! Quote Honda Accord 4 Door Current System - (2) 12'' Mtx Thunder 5500's (1) Alpine Mrp-m1000 @4Ω (1) Pioneer Deck Deh-3500 (1) American Legacy 1.0 Farad Capacitor (1) Stinger Voltage Meter (Blue) Big 3 Knu 1/0 Box 3.4^3@37hz Youtube. Link to comment Share on other sites More sharing options...
Demo402 Posted August 12, 2009 Author Report Share Posted August 12, 2009 You can only get a 1ohm load or a 4 ohm loadhttp://www.the12volt.com/caraudio/woofer_c...sp?Q=2&I=42 You could wire it to 1ohm and impedence rise and box rise should put it over 2 ohms, but still be careful about it... When you say "Impedence rise and box rise" What exactly do you mean by this? Quote Honda Accord 4 Door Current System - (2) 12'' Mtx Thunder 5500's (1) Alpine Mrp-m1000 @4Ω (1) Pioneer Deck Deh-3500 (1) American Legacy 1.0 Farad Capacitor (1) Stinger Voltage Meter (Blue) Big 3 Knu 1/0 Box 3.4^3@37hz Youtube. Link to comment Share on other sites More sharing options...
Boon Posted August 13, 2009 Report Share Posted August 13, 2009 (edited) When you say "Impedence rise and box rise" What exactly do you mean by this? It means he's quoting some buzz-words he's heard SPL guys using... box rise and impedance rise are the same thing... Because your speakers are an inductive reactive load the impedance will rise above the 'nominal' resistance when the subs are playing. However if you clip it you get no reactance and your amp sees the DC resistance = protect or smoke. Also some frequencies will have very very little rise... like 0.1 ohms... which isn't enough to keep an amp alive at half it's rated impedance. I had a rant about this a while ago (http://www.stevemeadedesigns.com/board/ind...c=46770&hl=), it's one of my pet peeves. Impedance rise will not save you, the amp is rated at 2 ohms for a reason. Wire it to 4 ohms, or get a different amp, or get another amp and run 1 on each sub @ 2 ohms. Edited August 13, 2009 by Boon Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
SQMonte Posted August 13, 2009 Report Share Posted August 13, 2009 Can anyone post the diagrams for wiring 2 dvc 4ohm subwoofers to a mono amp that is 2 ohm stable.i know theirs series and parallel but not exactly on the way there both wired! Thanks! -Ryan 2 DVC drivers with Voice Coils in Series / Parallel Connecting the two voice coils of each driver in series (+ to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances: Dual-6 Ohm Subwoofers: 6 Ohms Dual-4 Ohm Subwoofer: 4 Ohms Dual-2 Ohm Subwoofer: 2 Ohms Dual-1.5 Ohm Subwoofer: 1.5 Ohms 2 DVC drivers with Voice Coils in Parallel / Parallel Connecting the voice coils of each driver in parallel (+ to +, - to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances: Dual-6 Ohm Subwoofers: 1.5 Ohms Dual-4 Ohm Subwoofers: 1 Ohm Dual-2 Ohm Subwoofers: 0.5 Ohm Dual-1.5 Ohm Subwoofer: 0.38 Ohms Quote Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f Link to comment Share on other sites More sharing options...
