So what i am looking at, is 2, DC lvl 3 15's, and the space i have to work with is 31" wide, 17" tall, and 30" deep, and according to REboxcalc, i have everything tuned too 33.5 hz..
sorry about the blue crap, stupid screen shot program..
anyway, would this box work for the level 3 subs??
http://dcsoundlab.com/specs.html
sorry if this is a dumb question..
How exactly are you planning to put 2 15's in a 3 cuft box? unless I read something wrong.
Car - 99 Neon Sport
Batt - 1 Redtop up front On 200A Excessive Amperage alt
Sub - 2 12" Kicker L7's in ~2 cuft @ 36hz each on a Xtant X1001 @ 1 ohm
Front Highs/Mids - JVC CS-FS6 and Infinity 6022i on Xtant A2002
Rear Highs/Mids - None
HU - Pioneer DEH-P8600MP
1/0 wire ran thru entire car aswell as big3
DB - 144.5 @ Dash.
no it wont be wide enough for 2 15's. they alone are about 16 inches wide plus the 2inch port is like 34inchs. you only have 32 avalable. also the box is about half the size that it needs to be. dont try to cram woofers into space. do it right. give them the space they need. try either 1 15, or 2 12's. that would work. itll be way louder than 2 15's crammed in a box that is way too small.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
the box has enough cubic feet for two of those subs but it doesnt look like you have enough port. I believe you need between 12 and 16 square inches of port per cubic feet. your box is approx 7.5 cubic feet so you need between 90 and 120 square inches of port. I may be wrong tho.. but i think that is right. what are your port diemensions?
edit: i did all of my math wrong and I didnt exactly look closely at the picture.. lol.. it says right there the theres only 3 cubes of spaces.. ignore everything that i said above.. wow lol.. guess i should look more closely before replying.. :crazy:
Edited by dlesman
sealed they would be ok in 3cubes... 2 12s would be ok in that enclosure, u need more port tho
ported u need ~6cuft and 12sqin of port per cuft
much bigger box and much bigger port are needed
Edited by Decaf
note: math isnt my strong point so if i did my math wrong than well everything i just said is useless.
lol, everything u said is useless
he has 3cuft after displacement total... thats enough for 1 15
the port length/width was 15.5/2"..
maybe i need to go back to the 12's..
what about 1, level 4, 18? or is the box to small..
damn this is harder then it should be..
too small... needs 5.75cuft after all displacement and 80+ sqin port
wait, bigger box for 2, 15's or 2, 12's?
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
