how much more port space do you suggest?
12-16sqin per cuft of internal volume... 14sqin/cuft is a nice average... depends how big u can make ur box too
u need to post ur max dimensions u want the box to be... ur making this too hard because its all in relation
so ur port area depends how big the box is in the first place
max box size is 31" wide, 12" tall and 30" deep..
how can u fit two twelves with only 12" height... u need 13" height, u might be able to get away with 12.5"
u should do:
31w*13h*28d
3.96cuft
33.43hz
5" wide port
14.5sqin/cuft of port
the piece of wood for the port is 21.5" long
so with a max width of 31"... that means 12 for each sub... so 24" + 5" for the port plus 1.5" for both side of the box... that leaves you with 1/2" between each speaker... so put some dowel rod from baffle to back, top to bottom and side to port wall side... i included bracing in the above calulations...
u should do:
31w*13h*28d
3.96cuft
33.43hz
5" wide port
i wanna say this is where all the numbers needed to go..
but the tuning is always at 29..
  • Who's Online   1 Member, 1 Anonymous (See full list)
