hitman45400 Posted August 13, 2009 Report Share Posted August 13, 2009 So what i am looking at, is 2, DC lvl 3 15's, and the space i have to work with is 31" wide, 17" tall, and 30" deep, and according to REboxcalc, i have everything tuned too 33.5 hz.. sorry about the blue crap, stupid screen shot program.. anyway, would this box work for the level 3 subs?? http://dcsoundlab.com/specs.html sorry if this is a dumb question.. Quote Link to comment Share on other sites More sharing options...
B4SSB0Y Posted August 13, 2009 Report Share Posted August 13, 2009 How exactly are you planning to put 2 15's in a 3 cuft box? unless I read something wrong. Quote Car - 99 Neon Sport Batt - 1 Redtop up front On 200A Excessive Amperage alt Sub - 2 12" Kicker L7's in ~2 cuft @ 36hz each on a Xtant X1001 @ 1 ohm Front Highs/Mids - JVC CS-FS6 and Infinity 6022i on Xtant A2002 Rear Highs/Mids - None HU - Pioneer DEH-P8600MP 1/0 wire ran thru entire car aswell as big3 DB - 144.5 @ Dash. Link to comment Share on other sites More sharing options...
troy Posted August 13, 2009 Report Share Posted August 13, 2009 no it wont be wide enough for 2 15's. they alone are about 16 inches wide plus the 2inch port is like 34inchs. you only have 32 avalable. also the box is about half the size that it needs to be. dont try to cram woofers into space. do it right. give them the space they need. try either 1 15, or 2 12's. that would work. itll be way louder than 2 15's crammed in a box that is way too small. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs Link to comment Share on other sites More sharing options...
dlesman Posted August 13, 2009 Report Share Posted August 13, 2009 (edited) So what i am looking at, is 2, DC lvl 3 15's, and the space i have to work with is 31" wide, 17" tall, and 30" deep, and according to REboxcalc, i have everything tuned too 33.5 hz.. sorry about the blue crap, stupid screen shot program.. anyway, would this box work for the level 3 subs?? http://dcsoundlab.com/specs.html sorry if this is a dumb question.. the box has enough cubic feet for two of those subs but it doesnt look like you have enough port. I believe you need between 12 and 16 square inches of port per cubic feet. your box is approx 7.5 cubic feet so you need between 90 and 120 square inches of port. I may be wrong tho.. but i think that is right. what are your port diemensions? edit: i did all of my math wrong and I didnt exactly look closely at the picture.. lol.. it says right there the theres only 3 cubes of spaces.. ignore everything that i said above.. wow lol.. guess i should look more closely before replying.. Edited August 13, 2009 by dlesman Quote Link to comment Share on other sites More sharing options...
hitman45400 Posted August 13, 2009 Author Report Share Posted August 13, 2009 How exactly are you planning to put 2 15's in a 3 cuft box? unless I read something wrong. uhmm.. you know, that is a good question.. Quote Link to comment Share on other sites More sharing options...
Decaf Posted August 13, 2009 Report Share Posted August 13, 2009 (edited) sealed they would be ok in 3cubes... 2 12s would be ok in that enclosure, u need more port tho ported u need ~6cuft and 12sqin of port per cuft much bigger box and much bigger port are needed Edited August 13, 2009 by Decaf Quote Link to comment Share on other sites More sharing options...
hitman45400 Posted August 13, 2009 Author Report Share Posted August 13, 2009 the port length/width was 15.5/2".. maybe i need to go back to the 12's.. what about 1, level 4, 18? or is the box to small.. damn this is harder then it should be.. Quote Link to comment Share on other sites More sharing options...
Decaf Posted August 13, 2009 Report Share Posted August 13, 2009 the box has enough cubic feet for two of those subs but it doesnt look like you have enough port. I believe you need between 12 and 16 square inches of port per cubic feet. your box is approx 7.5 cubic feet so you need between 90 and 120 square inches of port. I may be wrong tho.. but i think that is right. what are your port diemensions?note: math isnt my strong point so if i did my math wrong than well everything i just said is useless. lol, everything u said is useless he has 3cuft after displacement total... thats enough for 1 15 Quote Link to comment Share on other sites More sharing options...
Decaf Posted August 13, 2009 Report Share Posted August 13, 2009 the port length/width was 15.5/2"..maybe i need to go back to the 12's.. what about 1, level 4, 18? or is the box to small.. damn this is harder then it should be.. too small... needs 5.75cuft after all displacement and 80+ sqin port Quote Link to comment Share on other sites More sharing options...
hitman45400 Posted August 13, 2009 Author Report Share Posted August 13, 2009 sealed they would be ok in 3cubes... 2 12s would be ok in that enclosure, u need more port thoported u need ~6cuft and 12sqin of port per cuft much bigger box and much bigger port are needed wait, bigger box for 2, 15's or 2, 12's? Quote Link to comment Share on other sites More sharing options...
