Moore941 Posted August 13, 2009 Report Posted August 13, 2009 Well i bought a 500.2 not to long ago off a member here and has been working perfectly until tonight on my way home, i jumped on the interstate and i turned my mids and highs up and they kept cutting out, i am running this amp at a 2ohm brigded load, I noticed my voltage with just this amp was dipping into the 12's and when it did that is when the amp cut out on me, has never made more than just a few tenths difference before. I have not been able to troubleshoot anything yet but has anyone else had a problem like this, also noticed if u look at the amp from the input side the top left corner is burning hot, Could this just be a loose ground issue, for some reason i doubt it but as i have not been able to check yet im unsure, Anyone with experience with rockford amps please add ur input and what u believe i should troubleshoot. Thx, Kyle 2000 White Dodge Durango 5.9L Flowmaster 40 Series through 2 1/2" with and open cat. 1 Dc lvl5 18 4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2 Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire shootin for 145+
Boon Posted August 13, 2009 Report Posted August 13, 2009 It's at 2 ohm bridged? Are you running your mids and highs mono o__O I'm not 100% sure that it will like that load... 10.x volts fo' life!
Moore941 Posted August 13, 2009 Author Report Posted August 13, 2009 It's at 2 ohm bridged? Are you running your mids and highs mono o__OI'm not 100% sure that it will like that load... Do u think that could be the issue and if so, would switching clear to 4 ohm per channel clear up my issues or do you think internal damage is already done? Edit: 500th Post Double Edit: much simpler lol 2000 White Dodge Durango 5.9L Flowmaster 40 Series through 2 1/2" with and open cat. 1 Dc lvl5 18 4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2 Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire shootin for 145+
