Rockford fosgate bd1500 2003 model problems
dt64bulldog
my friend has this connected to 2 l7 15's and it just started going into protect mode as soon as he turns his car on it goes straight into protect
2 18's Fi SSD All Options Dual 2 ohm
Rockford Fosgate T20001 Bd
1/0 gauge Knukonceptz power wire
Pioneer Touch Screen Navigation AVIC F700
13.62 cu ft box ..28 hz
250 amp alternator
2 kinetik 2000 batteries
Xs Vcm Module
Most likely he is running the amp at the wrong impedence or he is not getting enough voltage to the amp from the cars charging system.
Its a 2 ohm amplifier and if the voltage from the car gets close to 10 volts it will shut down.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Do you have any details that you can offer?
he could be running it a t like 0.5 ohms if the has the 2 ohm speakers.
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
Without enough info I'm going to say check your ground wire from the amp, check the impedance load from the subs.
Make sure your ground is going straight to the sheet metal of the vehicle, no paint under,make sure its not hooked to a seat belt bolt.
Go to the sheet metal strip the paint off, drill a hole and use a good quality screw and a lock nut.
If you find out your at .5 ohm impedance with your subs get that changed quick. Do not keep abuseing the amp or it will die eventually.
  • Who's Online   0 Members, 0 Anonymous, 690 Guests (See full list)
