Guest Nismofreak
I knew it was a joke. j/j= just joking if you didn't know
This thread=totally jacked.
But to answer the original guy's question, nobody can tell you how to build your box better than you.
Power Acoustik fubar 12
sony xploding amp
2 ft^3 box @ 35hz
Guest Nismofreak
Dam we need to get on topic. Thanks for the distraction roscoe
You can't just explain how to build a box to someone who knows nothing. I studied this site for like 3 months before I even attempted a box and both of my first two boxes were all fawked up. You just gotta read read read and get your hands dirty.
sony xploding amp
2 ft^3 box @ 35hz
Guest Nismofreak
Not really i think we helped him out. I say make a new box using win ISD helps you build a box making it easy and fun
well you guys helped a lil, i just awnted some box sizes like 1.5 cubes to 2 cubes for each sub dual type sharing one port, so i was hoping someone would have had one built and tuned to some good frequency so i coulda jsut based mine off there design.
well the max height is 17, max width is 40 and the depth of the trunk is about 24
Better make sure you can actually fit that box through the trunk opening. Just because you have the room doesnt mean you have the ability....
As far as a box design, what you are looking for is a pretty complex design, and I would not reccomend it for your first build. You actually gain dB by having your woofers in a common enclosure. So, I would suggest just going with a normal slot port design to one side with your two subs on the other side...4 cubes tuned to 35Hz with around 50sq.in. of port should do just fine...make sure you roundover your port though....
If you need an actual design, shoot me a PM and ill draw something up for you...
2001 Blazer
Pioneer 5900IB - (2) DC Level 3 10"s - Sundown 1500D
  • Who's Online   0 Members, 0 Anonymous, 678 Guests (See full list)
